H10 5/6GB Firmware Version 2.53
[improved Features]
1. Shortened booting time
- Booting time has shortened in half(based on 1,000 tracks).
It may vary the number of tracks in the device.
2. Improved Touch Pad operation
- It used to scrolling around the menu when touch pad is keep pressed. Now it is changed to stop at the last menu and move to the top by clicking it once more.
מעניין מאוד, ננסה את זה יותר מאוחר
3. Shortened accessing time when accessing playlist
4. Improved HDD running
- HDD is turning off after 8 second when it's not accessed for excessive running.
5. Improved file recognition
- Now it can recognize files up to 1000 on each TEXT, Photo and Browser mode.
(It was 600 before.)
[Fixed Bugs]
1. Fixed the bug that sound was distorted on User EQ.
2. Fixed the bug that backlight of LCD wasn't illuminated when it's awakening from Stand by mode.
3. Fixed the bug that incorrect tracks were browsed when it was sorted by genre.
4. Fixed the occasional bug that recording files were named with an unreal date such as June 31st or 32nd.
5. Fixed the bug that LCD turned off when NEXT or PREV button is keeping pressed on Text viewer.
6. Fixed the bug that increased volume when PAUSE/PLAY button is frequently pressed after adjusting EQ during playback.
7. Fixed the bug that malfunctioned when it was browsing an images as small as 1 pixel on Photo mode.
8. Fixed the bug that distorted sound when PAUSE/PLAY button is frequently pressed during playback.
9. Fixed the occasional bug that sound was cutting or LCD was on hold when NEXT/PREV button is frequently pressed during recording file playback.
http://www.iriver.com/html/support/download/sudw_view.asp?idx=819
