שאלה בקשר לCATALYST
שלום לכולם רציתי שמיהשו יסביר לי בדיוק מה זה CATALYST
והאם זה רק לכרטיסים BBA
ובכלל כל מה שצריך לדעת עליו
תודה ! זה חשוב
CATALYST - Commitment, Confidence and Capability
ATI introduces CATALYST - industry-leading software suite that enhances and accelerates the visual experience. The suite is a package that consists of the latest driver, HYDRAVISION (multiple monitor management software), MULTIMEDIA CENTER and REMOTE WONDER support.
Confidence
Industry's most stable 3D acceleration software
Fully supported by ATI's customer support
Featuring SMARTGART - a diagnostic tool that determines the optimal settings to ensure maximum stability. With SMARTGART, the display driver will automatically test the AGP capability upon its initialization and dynamically adjust the necessary settings based on the test results. This provides users with a more stable system
Capability
CATALYST software supports component output for all RADEON 8500 family of graphics cards and ALL-IN-WONDER® RADEON 8500DV. This provides the highest quality method to deliver HDTV support and allow users to use their PCs as a central entertainment hub while watching high-definition TV or playing games
CATALYST provides plug-ins for the REMOTE WONDER software. This lets users control applications such as WINAMP and Microsoft® POWERPOINT with REMOTE WONDER
CATALYST includes a new Direct 3D and OpenGL® control panel that gives users full control over performance and image quality settings
Commitment
ATI is committed to providing frequent updates of all CATALYST elements. For example, the driver element of the CATALYST will be updated as frequently as 8-10 times a year! Each update will focus on improving CATALYST attributes
Introducing CATALYST CREW - ATI's end user feedback program. Join now and let us know what you think of CATALYST. For more information, see CATALYST Crew Contest.
לא כתוב שם אם זה רק לBBA
והתכוונתי שתסביר במילים שלך בכל זאת תודה
ATI הבינו שהחולשה המרכזית שלהם היא הדרייברים שהם משחררים או יותר נכון, בקושי משחררים. הם פשוט... אם לומר זאת בעדינות... מסריחים (הדרייברים).
החברה החלה להתעלות על עצמה ולהשקיע יותר בתחום, על מנת שהכרטיסים ינוצלו כראוי עם כמה שפחות בעיות תאימות ובאגים למיניהם המופיעים כשמריצים אלמנטים של תלת מימד.
בקיצר, מכאן והלאה... אני כמעט משוכנע שיהיה איכותי.
הקאטאליסט מותאמים גם לכרטיסים מתוצרת ATI וגם לכרטיסים של חברות צד שלישי המשתמשות במעבדים הגרפיים של החברה.
בעמוד הראשי של אתר הבית של ATI, יש לך שני איזורים.
BUILT BY ATI & POWERED BY ATI...
בהתאם לכרטיסך, אתה בוחר את האיזור המתאים ומוריד את הדרייבר התואם.
Built By Ati = כרטיסים מתוצרת ATI.
Powered By Ati = כרטיסים מתוצרת חברות אחרות המשתמשים במעבדים הגרפיים של ATI.
בקיצר אני קונה את ה9700 של HERCULES
או GIGABYTE בא הביתה מחבר ת'כרטיס מוריד CATALYST?
תודה רבה עזרת לי מאוד!
ההרקולס וכן, זו כל התורה.
קאטאליסט גירסה 7.76 ותיהיה מרוצה.
יופי סבבה
תודה!
בכיף :xyxthumbs:
תתחדש לך!
