זיכרון של PATRIOT ללוח ASUS A8N32-SLI Deluxe
שלום למבינים
קניתי את הלוח הבא
האם הזיכרון הזה יתאים לו??
Patriot 2GB PC3200 DDR Dual Channel Memory KIT
PATRIOT:
Outpost #: 4453786
MODEL: PDC2G3200LLK
Patriot Dual Channel PC-3200 memory is designed to operate at extreme low latency timings at 400MHz on both Intel and AMD based motherboards. SPD programmed at an super low latency of 2-3-2-5 (tCAS-tRCD-tRP-tRAS), our DC PC-3200 memory is designed for simple plug and play operation. It is as simple as install and go. The secret to our Dual Channel line is in our manufacturing process as modules are kitted from manufacturing. In addition, every one of our Dual Channel memory goes through rigorous compatibility testing and strict quality control as a pair to ensure operations and performance at their rated speeds and timings. Accompanied with our high quality premium heat spreaders and backed by our life time warranty, Patriot Dual Channel memory is right memory for the overclocking enthusiast in you.
יתאים גם יתאים.
