אני צריך תוכנה להמרה
חברה אני צריך תוכנה להמרה מקובץ audio ל mp3
ברוך הבא לפורום, בפעם הבאה תעשה חיפוש לפני פרסום שאלה.
Easy CD-DA Extractor
Easy CD-DA Extractor is 3-in-1 software that contains
Audio CD Ripper - Rips audio CDs with accurate, high-performance CD ripping engine. Bypasses 'copy-protections'. Reads badly scratched discs. Reports errors on the discs. Reads the track titles from the Internet. Writes ID3/ID3V2/metadata. Allows you to edit the metadata and specify the filenames for the ripped files, and more... (view screenshot)
Music Converter - Audio File Format Converter - Converts audio file formats from one format to another. Splits CUE Sheets and encodes the music to individual files. Allows you to edit the ID3/ID3V2/metadata, and rename the output files, and more... (view screenshot)
Audio CD Creator - Writes Audio CDs that are compatible with all home/car CD-players. Writes CD-Text. Supports CUE Sheets. Uses BURN-Proof for error-free CD burning. (view screenshot)
http://www.kotiposti.net/poiko/ezcddax9.exe
טוב אחי
תודה גבר
