אני רוצה לעשות oc ל5600xt שלי (ד"א הוא כן 128 ביט)
אלו הנתונים שקיבלתי מ riva tuner :
$ffffffffff Display adapter information
$ffffffffff ----------------------------------------------------------------
$0000000000 Description : NVIDIA GeForce FX 5600XT
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0314
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 3.0 (AGP 2.0 mode)
$0000000005 AGP status : enabled
$0000000006 AGP rate : 1x 2x 4x supported, 4x selected
$0000000007 AGP SBA : supported, enabled
$0000000008 AGP FW : supported, enabled
$0000000009 Base address 0 : de000000 (memory range)
$000000000a Base address 1 : c0000000 (memory range)
$000000000b Base address 2 : none
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : NV31 revision A1
$0100000001 Hardwired ID : 0310 (ROM strapped to 0314)
$0100000002 Memory bus : 128-bit
$0100000003 Memory type : DDR (RAM configuration 01)
$0100000004 Memory amount : 131072KB
$0100000005 Core clock : 234.000MHz
$0100000006 Memory clock : 199.500MHz (399.000MHz effective)
$0100000007 Reference clock : 27.000MHz
עכשיו אלו הנתונים שאספתי מ sisoftware:
Board Temperature : 32.0°C (Min 32.0°C; Avg 33.0°C; Max 34.0°C)
CPU Temperature : 46.5°C (Min 42.0°C; Avg 42.8°C; Max 47.0°C)
Power / Aux Temperature : 58.5°C (Min 58.0°C; Avg 58.5°C; Max 59.0°C)
Chassis Fan Speed : 3462rpm (Min 3444rpm; Avg 3465rpm; Max 3497rpm)
CPU Voltage : 1.49V (Min 1.49V; Avg 1.49V; Max 1.52V)
Aux Voltage : 1.54V (Min 1.52V; Avg 1.54V; Max 1.55V)
+3.3V Voltage : 3.22V (Min 3.20V; Avg 3.22V; Max 3.23V)
+5V Voltage : 5.11V (Min 5.08V; Avg 5.08V; Max 5.13V)
+12V Voltage : 11.61V (Min 11.55V; Avg 11.78V; Max 11.86V)
Standby Voltage : 4.90V (Min 4.87V; Avg 4.90V; Max 4.92V)
Battery Voltage : 3.36V (Min 3.34V; Avg 3.36V; Max 3.38V)
CPU Core Power : 55W (Min 55W; Avg 56W; Max 58W)
CPU Cooling System Thermal Resistance : 0.26°C/W (Min 0.16°C/W; Avg 0.18°C/W; Max 0.26°C/W)
אני די חדש בזה אז אני לא רוצה לעשות כל מיני טעויות מטומטות... (ד"א אני לא מוסיף עוד קירור)
אם תוכלו להסביר לי בכמה בערך אני יכול להאיץ את הכרטי זה יעזור לי מאוד?
תתחיל לעלות קלוקים !!
:xyxthumbs:
אבל איך אני בודק אם המערכת שלי יציבה אחרי שאני מעלה את המהירויות...? והקירור מספיק טוב בשביל oc מתון?
יש לי עוד שאלה....riva tuner פשוט משנה את הדרייבר של הכרטיס מסך נכון? אז אם אני אעדכן את הדרייברים אני שוב אצטרך לעשות oc, איך זה בדיוק עובד?
דבר ראשון אל תעשה דאבל פוסטינג כי המנהלים ינעלו את הדיון . איך אתה בודק ? אתה פשוט מנסה תעלה כל פעם בחמש בליבה וחמש בזיכרון ככה תבחן את זה (בתוכנות כמו 3dmark וכו ) ואז אם זה בסדר (הכרטיס לא מתחמם יותר מדי או משהו כזה ) תמשיך לעלות עד שמשהו יעצור אותך ודבר איתנו אז .
טוב החלטתי להשתמש coolbits... עכשיו, לא הבנתי כמה דברים:
1. מה ההבדל בין ה2D ל3D בsettins ה?
2.כשאני לוחץ על ה" detect optimal frequencies" לפי מה הוא קובע את זה כי הוא הגביר די הרבה(בcore ל 363/235 ובmemory ל400/658)? ואין לי בכלל קירור על הכרטיס אז אני לא רוצה שעוד חודש זה פשוט ישרף.
3. יש אפשרות של fan always on שזה קצת מוזר כי כמו שציינית אין לי קירור על הכרטיס
מאיפה שהעלת קלוקים אתה יכול לצלם את המסך ולעלות לאינטרנט שנראה?
אחרי שאני אראה אני אוכל להסביר לך דברים כי כי באמת טיפה מוזר ככה
אין צורך לעלות ב 2d כלומר דו מימדי לא יעזור לך בשיט , תעלה רק ב 3D רק שם העלאת הקלוקים משתלמת . בכללי עדיף לך לעשות oc דרך riva tuner יותר נוח ,אבל אם אתה מתעקש have it your way .
3. אז אם תפעיל אתהאפשרות הזאת זה פשוט לא יפעל , מה מטרת השאלה :screwy:
אז תשמיך לעלות תבדוק טמפ' ותודיע אם יש לך עוד בעיה .
אני בכל זאת אשמח לתמונת מסך ממנו
איך אפשר לבדוק טמפ' אם אין לי חיישן טמפ' (52FX)?
eversest ,speedfan אתה יכול להוריד מהאתר .
אבל הוא לא יכול לבדוק טמפ' של הכרטיס מסך כי אין לו חיישן
הנה תמונה
עריכה:
הצבעים ככה כדי להוריד את גודל הקובץ
[attachment deleted by admin]
מה זה הצבעים האלה?
שאתה רוצה לעלות תמונה תשמור אותה בשם דרך הצייר בפורמט JPEG...
:xyxthumbs:
