אילו זכרונות להתקין על המחשב שלי?..
אהלן,
יש לי מחשב זקן (בן 5+,p3 733),מצרף פרטים אודות לוח האם שבו,הזכרונות וכ"ו.
(יודע שזה ארוך ומתנצל מראש.
פשוט נראה לי שזה הכרחי)
קבלו:
Entire System
Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD
Model : MS-6199
Version : 1.X
System Mainboard
MP Support : No
Model : MS-6199 (VT693)
Version : 1.X
BIOS ID : 01/01/2000-692-596-W977-2A6LGM4EC-00
Chipset : VIA VT82C693 Apollo Pro Plus Chipset
Memory Controller
Error Detection Method : None
Error Correction Capability : 1-bit
Supported/Current Memory Interleave : 4-way / 1-way
Number of Memory Slots : 3
Maximum Installable Memory : 768MB
Maximum Module Size : 256MB
Supported STD/FPM/(B)EDO Speeds : 70ns, 60ns
Supported SDRAM Speeds : PC66, PC100
Supported Memory Types : STD, FPM, EDO, Parity, ECC, SIMM, DIMM, SDRAM
Supported Memory Voltages : 3.3V
Physical/BIOS Memory Banks
BANK_0 (RASL-0 RASL-1) : 64MB DIMM SDRAM single-bank
BANK_1 (RASL-2 RASL-3) : 64MB DIMM SDRAM single-bank
BANK_2 (RASL-4 RASL-5) : 128MB DIMM SDRAM single-bank
System Chipset
Model : VIA Technologies Inc VT82C691/693A/694X Apollo Pro/133/133A System Controller
Bus(es) : ISA AGP PCI USB FireWire/1394 SMBus/i2c
Front Side Bus Speed : 1x 133MHz (133MHz data rate)
Max FSB Speed / Max Memory Speed : 1x 133MHz / 1x 133MHz
In Order Queue Depth : 1 req(s)
Logical/Chipset Memory Banks
Bank 0 Setting : 64MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank 2 Setting : 64MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank 4 Setting : 64MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank 5 Setting : 64MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Multiplier : 1/1x
Power Down Mode : No
Fixed Hole Present : No
Memory Modules
Memory Module 1 : Samsung M3 66S0823DTS-C75 3A688201 64MB 8x(8Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz)
Memory Module 2 : Samsung M3 66S0823DTS-C75 3A1B8101 64MB 8x(8Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz)
Memory Module 3 : Micron 16LSDT1664AG-10EC7 50032BDE 128MB 16x(8Mx8) SDRAM PC100-222-622 (CL3 upto 125MHz) (CL2 upto 100MHz)
Environment Monitor 1
Model : Winbond W83782D SMB
Version : 3.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 74.0°C / 165.2°F
CPU Temperature : 42.0°C / 107.6°F
Cooling Device(s)
Auto Fan Speed Control : No
Power / Aux Fan Speed : 6250rpm
Voltage Sensor(s)
CPU Core Voltage : 1.66V
Aux Voltage : 1.47V
+3.3V Voltage : 3.34V
+5V Voltage : 4.95V
+12V Voltage : 11.98V
-12V Voltage : -12.20V
-5V Voltage : -5.15V
AGP Bus
Version : 1.00
Speed : 66MHz
Current Data Transfer Rate : 2x 66MHz (132MHz data rate)
Side Band Enabled : No
Side Band Support : Yes
Fast-Writes Enabled : No
Aperture Size : 64MB
PCI Bus(es)
Version : 2.10
No Bridges : 1
PCI Bus 0 : 32-bit PCI (33MHz)
Multiplier : 1/4x
LPC Hub Controller 1
Model : VIA Technologies Inc VT82C596/A/B "Mobile South" PCI to ISA Bridge
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Speed Multiplier : 1/4x
Speed : 8MHz
DMA Multiplier : 1/2x
DMA Speed : 4MHz
USB Controller 1
Model : VIA Technologies Inc VT83C572,VT82C586/A/B,VT82C596B,VT82C686A/B USB Controller
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
FireWire/1394 Controller 1
Model : Creative Labs Audigy IEEE1394 Firewire Controller
Version : 1.10
OHCI Interface : Yes
Enhanced 1394a Support : No
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : Intel PIIX4 SMBus / compatible
Speed : 16kHz
Expansion Slot(s)
ISA : ISA 16-bit 5V FullLength
PCI (13h) : PCI 32-bit 5V FullLength Available
PCI (Eh) : PCI 32-bit 5V FullLength InUse (3COM Corp, Modem Division (Formerly US Robotics) USR 56k Internal WinModem)
PCI (10h) : PCI 32-bit 5V FullLength Available
PCI (12h) : PCI 32-bit 5V FullLength InUse (Creative Labs SB0090 Audigy Player )
PCI (8h) : PCI 32-bit 5V FullLength Available
AGP (8h) : AGP 32-bit 5V FullLength Available (ASUSTeK Computer Inc V7100PRO/SI416)
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO Compatible - Floppy / None
COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
Keyboard : Keyboard Port - None / PS/2
PS/2 Mouse - Detected : Mouse Port - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice N224 : SMBIOS/DMI information may be inaccurate.
Tip T2505 : System does not support memory error detection. Some memory errors may go unnoticed.
Warning W2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Warning W231 : IOQD is set too low. Performance will suffer.
Warning W2523 : Memory bus speed exceeds memory rated speed. Reduce memory bus speed.
Notice N2527 : Compensation was added to external temperature sensors.
Warning W2518 : Mainboard temperature is too high!
Tip T2 : For more information about tips, press F1 and scroll to the Tips section.
צלחתם את המגילה?אתם עדיין איתי?
מצויין! :xyxthumbs:
כמו שאפשר לראות מותקנים שלושה סטיקים של זכרון ,הנה הם שוב למי שפספס:
אם אני רואה ומבין נכונה,שניים מהם,אלה מתוצרת סמסונג עובדים במהירות של 133 וזה של מיקרון במהירות של 100...
המערכת תומכת בזכרונות במהירות של 133,הנה ציטוט מבליל האינפורמציה שלמעלה:
איך בדיוק זה מדרדר לי את הביצועים?
(אני זוכר שזה בעייתי רק לא זוכר את ההסבר).
בזמנו ביקשתי מהמקום ממנו קניתי את המחשב שיוסיפו לי זכרון,הם התקינו אותו והם אחראים למחדל (בהנחה שיש אחד כזה).
אני עובד עם win98se
מה הכמות המקסימלית של זכרון שמערכת הפעלה זו יודעת לנצל באופן אפקטיבי (נדמה לי שקראתי בעבר שאין טעם לשים
יותר מ-256MBׂ.)
האם כדאי לי להעיף את שלושת הסטיקים ולשים במקומם אחד של 256?
חושבים שתהיה לי בעיה למצוא זכרונות sdram?
מישהו יכול להסביר לי את האזהרה הבאה:
"Memory bus speed exceeds memory rated speed. Reduce memory bus speed"?
אני מתכוון לקנות לעצמי מחשב חדש ואת זה שפרטיו מופיעים פה להעביר לאחותי.
הוא אמור לשמש בגדול רק לגלישה באינטרנט.
(גם שימוש בכמה תוכנות אבל לא משהו כבד).
יש איזו בעיה להתחבר לאינטרנט המהיר (דרך הכבלים) עם WIN98SE?
שוב,מצטער על האורך ומודה מראש לעונים :)
שים שם 2 סטיקים של 256 133 מגה הרץ.
אבל יהיה לך קשה להשיג וגם די יקר.
הבעיה היא שכל הזכרונות ירוצו במהירות 100MHz כי ככה מדורג ה-Micron
בעיקרון לדעתי זה לא ייתן לך הבדל ביצועים ממש
לשאלה עם כמה זכרון Win 98SE מסוגל להתמודד תשאל בפורום Windows, הם מבינים יותר מאיתנו
אגב אין בעיה לגלוש באינטרנט מהיר עם Win 98SE
יש לי מחשב שהיה מחובר ככה לפחות שנה
