פורסם 2006 במרץ 320 שנים look 2 the pic why i got thats temprtora ? just yestarday i bought the Pc.. [attachment deleted by admin]
פורסם 2006 במרץ 320 שנים humm put your hundes on the hard drive to look if its realy that hot if yes try to put some 120mm that will cool it down
פורסם 2006 במרץ 320 שנים מחבר i have put there a 120mm :s07:and the temprtora didnt change :http://images.google.co.il/imgres?imgurl=http://www.thermaltake.com/images/cases/products/soprano/vb1000sns/vb1000sns.jpg&imgrefurl=http://www.thermaltake.com/xaserCase/soprano/sns/sns.htm&h=260&w=162&sz=27&tbnid=jswaxKTB97HEeM:&tbnh=107&tbnw=66&hl=iw&start=7&prev=/images%3Fq%3Dsoprano%26svnum%3D10%26hl%3Diw%26lr%3D%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official_s%26sa%3DN igot thats "marz" its full of "maorrem"
פורסם 2006 במרץ 320 שנים מחבר did you toched the hard drive to see if speed fan faking ? no but the pc moving slowly..
פורסם 2006 במרץ 320 שנים well try toch the hard drive to see if its realy that hot if yes try plug him with anoter molex cable
פורסם 2006 במרץ 320 שנים מחבר i have a another prop, when im lunch CSS i join 2 server and after any sencodes the pc dont move and i cant do any thing .. just 2 do restart i got a fuckin hard disk or what ? [attachment deleted by admin]
פורסם 2006 במרץ 420 שנים hummm are you aure that the 120mm works ? humm try to switch the molex may be the molex is fucked up humm if its dosnt help use your warrntey i drunk so dont think i got lame egnlish
פורסם 2006 במרץ 420 שנים מחבר hummm are you aure that the 120mm works ? humm try to switch the molex may be the molex is fucked up humm if its dosnt help use your warrntey i drunk so dont think i got lame egnlish i tried all the ways ... i think i got afuckin hard disk :@ why always me , look what iget when im open the PC..(pic) some one :s05: :'( [attachment deleted by admin]
פורסם 2006 במרץ 720 שנים 'well theis messege seems to try said that you got fucked up lame power supply !!!!wich power supply u got ? try to chgnae to more strong power supply
