פורסם 2006 בפברואר 2620 שנים i think that the T2500 with 7800 go + 1GB DDR2 667should be enoughhttp://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2627&p=5in a review the T2500 (YONAH 2GHZ=T2500)was as good as the 3800+and the 7800 GO is a pretty harccore GPUif u want to buy a lcd screen in israel it will cost you something like 400$add it to what u can get + 3 year warranty in israelit's the best deal
פורסם 2006 בפברואר 2620 שנים מחבר but if you add all these things the price goes up to over 2000-2500$I can get a much stronger desktop in less than half that price
פורסם 2006 בפברואר 2620 שנים מחבר ok, right now this is what i want to get. it's just slightly over the budget i set but it seems like a kickass setup so i don't mind. i'm just worried about custums, the warranty issue, and not damaging anything on the way back (do you think i should keep the retail boxes or repacke all the parts differently?)i'm not going to order until tomorrow night because they don't handle order on the weekend anyway so i still have time to change things. tell me what you think...Continue ShoppingIntel-compatible MotherboardsQty. Product Description Unit Price Savings Total PriceUpdate ASUS P5LD2 Deluxe Socket T (LGA 775) Intel 945P ATX Intel Motherboard - RetailModel #: P5LD2 Deluxe** This item is warranted through the product manufacturer only. what's this?Remove Remove Move To Cart Move To Wish List $152.99 $152.99Internal Hard DrivesQty. Product Description Unit Price Savings Total PriceUpdate Maxtor DiamondMax 10 6V250F0 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEMModel #: 6V250F0Remove Remove Move To Cart Move To Wish List $96.00 $96.00Memory - SystemQty. Product Description Unit Price Savings Total PriceUpdate pqi TURBO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Unbuffered Dual Channel Kit System Memory Model PQI25400-2GDB - RetailModel #: PQI25400-2GDB$20.00 Mail-in RebateRemove Remove Move To Cart Move To Wish List $179.93 $179.93ProcessorsQty. Product Description Unit Price Savings Total PriceUpdate Intel Pentium D 920 Presler 800MHz FSB LGA 775 Dual Core Processor Model BX80553920 - RetailModel #: BX80553920** This item is warranted through the product manufacturer only. what's this?Remove Remove Move To Cart Move To Wish List $258.00 $258.00Video CardsQty. Product Description Unit Price Savings Total PriceUpdate Leadtek WinFast PX7800GT Extreme TDH Geforce 7800GT 256MB GDDR3 PCI Express x16 Video Card - RetailModel #: PX7800GT EXTREME TDHRemove Remove Move To Cart Move To Wish List $289.00 $289.00Video Devices & TV TunersQty. Product Description Unit Price Savings Total PriceUpdate Hauppauge WINTV-PVR-150 PCI Interface Tuner Card - RetailModel #: 1045Remove Remove Move To Cart Move To Wish List $89.99 -$3.00 Instant $86.99Printer-friendly Version
פורסם 2006 בפברואר 2620 שנים WOLF,לא שולחים שתי הודעות רצופות באותו טרד. תשתמש בכפתור עריכה.קרא בבקשה את חוקי הפורום:http://hwzone.co.il/community/index.php?topic=59714.0
פורסם 2006 בפברואר 2820 שנים מחבר ok - i just placed the order.... where do you think i should order the other parts from? i'm going to order it asap so it'll be delivered by the time i get back to israel in a week and a half. thanks for all the help - wish me luck
פורסם 2006 בפברואר 2820 שנים תתחדש.שאר החלקים - מאיפה שבא לך. נעה, לוג'יק, פנדה או זיזג, מה שיוצא יותר זול.מ-ESP אני לא חושב שכדאי כי יש להם מבחר מאוד מאוד מצומצם של מארזים וספקים. № Code Product Price Quant. Summ0 2443 Citizen/Sony/Alps Black 1.44MB 3,5" FDD 49.00 ¤ 1 49 ¤1 4973 Coolermaster CAC-T05 Centurion 5 P/S Not Included Case 398.00 ¤ 1 398 ¤2 5499 Enermax 420W EG425P-VE FMA 20/24Pin Power Supply 420.00 ¤ 1 420 ¤3 6331 Thermaltake BigTyphoon CPU Cooler 251.00 ¤ 1 251 ¤ 1118 ¤נלקח מLOGICPC.CO.IL.דגם מחיר כמות כונן דיסקטים שחור 70 ¤ 1 COOLER MASTER Centurion 5 BLACK NO PSU 450 ¤ 1 FSP 400W ATX 12V (Version 2.0) 400W 12CM Fan 380 ¤ 1 THERMALTAKE BIGTYPHOON 255 ¤ 1 מחיר סופי: ¤ 1155מ-NOACOMP.CO.ILאני חושב שהכי זול ייצא לך מלוג'יק. אבל תשווה...
פורסם 2006 בפברואר 2820 שנים מחבר ,I browsed around and I will probably get it from LOGIC I looked at alot of cases but I really like the one you suggested, it's doesn't look like a plastic you like most of the cases I saw and it seems very practical. the 532 also looks ok but i don't really like that design. I just hope that the pc won't get too hot and stay silent. the case comes with two fans, and with the bigtyphoon it should be good right? I can't wait to get all the parts and get home and assemble it!
פורסם 2006 במרץ 820 שנים מחבר אוקיי! כמה טוב להיות בבית הגעתי לפני יומיים עם כל הרכיבים, ביקרתי בLOGICPC ברמת גן והשלמתי את החוסרים, ביקרתי בחנות נוספת ורכשתי מסך סמסונג 930B. נתקלתי בכמה בעיות התקנה אבל כולן נפתרו והמערכת עומדת על הרגליים כרגע, למרות שנשארו לי המון הגדרות והתקנות נוספות, והיא מתפקדת מצויין. ממש ממש מצויין. לא חלמתי על כאלו ביצועים תודה על הייעוץ...
