פורסם 2006 בפברואר 2420 שנים hey there.well, this new computer will be mostly used for multimedia (has to have a tv-out), internet & office, graphic design (photoshop mostly), and some video editing (mostly ripping DVDs and converting videos to ipod format). I'm also going to use it for some gaming so I want it to be able to run new games well - but it's the least important thing.I already have a DVD burner and DVD drive so there's no need for new ones. I also have a hard drive but I want to add another one - at least 250GB.I don't really have a budget limit, but keeping it under 1000$ would be nice. I'm in the United States right now and I will be coming back in a few weeks so I thought I'd use the chance to buy from newegg.com and save some money.I'm going to have to carry it back to Israel so I think I won't be buying the case or the monitor here (so basically just the cpu, motherboard, memory, video card, hard drive, floppy and cooling), Also if you think any of the parts might be vulenrable and shouldn't be carried on a plane by me, let me know.ThanksBen
פורסם 2006 בפברואר 2420 שנים My Saved Items Intel-compatible Motherboards Qty. Product Description Unit Price Savings Total Price 1 Gigabyte GA-8I945P-G Socket T (LGA 775) Intel 945P ATX Intel Motherboard - Retail Model #: GA-8I945P-G ** This item is warranted through the product manufacturer only. what's this? Remove Remove Move To Cart Move To Wish List $98.00 $98.00 Internal Hard Drives Qty. Product Description Unit Price Savings Total Price 1 Maxtor DiamondMax 10 6V250F0 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM Model #: 6V250F0 Remove Remove Move To Cart Move To Wish List $96.00 $96.00 Memory - System Qty. Product Description Unit Price Savings Total Price 1 pqi TURBO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Unbuffered Dual Channel Kit System Memory Model PQI25400-2GDB - Retail Model #: PQI25400-2GDB $20.00 Mail-in Rebate Remove Remove Move To Cart Move To Wish List $179.93 $179.93 Processors Qty. Product Description Unit Price Savings Total Price 1 Intel Pentium D 920 Presler 800MHz FSB LGA 775 Dual Core Processor Model BX80553920 - Retail Model #: BX80553920 ** This item is warranted through the product manufacturer only. what's this? Remove Remove Move To Cart Move To Wish List $258.00 $258.00 Video Cards Qty. Product Description Unit Price Savings Total Price 1 GIGABYTE GA-NX6800G256DB-ED Geforce 6800GS 256MB GDDR3 PCI Express x16 Video Card - Retail Model #: GA-NX6800G256DB-ED Remove Remove Move To Cart Move To Wish List $182.99 $182.99 total of 814$ before rebates. now, this has a very good very OCable cpu, good solid motherboard, pretty darn good video card thats not too expenssive. lots of good quality ram and a HD with 16mb cache and NCQ capabilities. the video card has TV out and HDTV capabilities, but it doesnt have VIVO. so i suggest you grab this on the way: http://www.newegg.com/Product/Product.asp?Item=N82E16815116625 to make the pc ideal as a media center. as for cpu cooling heat sink and a floppy: i suggest you buy them here, cooling can be very heavy and the price difference on floppies doent justify the flight overweight enjoy.
פורסם 2006 בפברואר 2420 שנים מחבר thank you honestly i don't like oc-ing so i probably won't change anything. do you think these parts as-is without oc will still do the job for my needs? about the video capture card, that's a very good idea (although there's one really bad review in the link you gave) as for the HD - is that SATA2? Now, as for the cooling heat sink, case and floppy, what do you reccomend that will work best with the other parts you listed here? I'll probably order this in a day or two but i'd like to get some more replies and ideas before i do also, I know my way around pcs pretty well and i've installed pci cards myself, but i never actually put a complete pc together, is there a good simple guide online you know of? or do you think i should ask/pay someone else to do it for me? Thanks Ben
פורסם 2006 בפברואר 2420 שנים מחבר done.also, I've been comparing monitor prices and newegg.com is so much cheaper than any other israeli store. too bad it's too heavy and fragile to carry...
פורסם 2006 בפברואר 2420 שנים 1) למדיה סנטר, ופוטנציאל אוברקלוק יותר טוב הייתי לוקח את הלוח הזה:http://www.newegg.com/Product/Product.asp?item=N82E16813131539ובודק כמה עולה ה WIFI שלו עם ה HD TV/RADIO TUNERקרא בביקורת:http://www.tbreak.com/reviews/article.php?cat=mobos&id=379&pagenumber=22) אם אתה עובד עם קבצים גדולים בפוטושופ הייתי שוקל לקנות 4 גיגה זכרון ולא 2.3) אם משחקים חדשים חשובים לך, הייתי שוקל X1900XT או לפחות 7800GT.4) יהיה לא חכם, לא להזמין ספק טוב עם המערכת. כמה דוגמאות, יש עוד הרבה. השאלה מה בסופו של דבר התקציב יאפשר לך:http://www.newegg.com/Product/Product.asp?Item=N82E16817103931http://www.newegg.com/Product/Product.asp?Item=N82E16817104014http://www.newegg.com/Product/Product.asp?Item=N82E16817194003http://www.newegg.com/Product/ProductList.asp?Submit=ENE&N=2010320058+50001550&Subcategory=58&description=&srchInDesc=&minPrice=&maxPrice=&ATTR2=2010320058+50001550&ATTR3=&ATTR4=&ATTR6=&ATTR7=&ATTR9=&ATTR10=5) קרור שקט וטוב לפרסלר. THERMALTAKE BIG TYPHOON למשל.
פורסם 2006 בפברואר 2420 שנים מחבר of course I want to buy a good power source for the system, but isn't it usually a bit heavy? I was going to buy it in Israel when I come back.Another question - how much will the same system cost me in Israel? Will I have no problem if i need to use the warranty on any of these parts? if the difference is not substantial, do you think it's wiser to just buy it in Israel?
פורסם 2006 בפברואר 2420 שנים thank you honestly i don't like oc-ing so i probably won't change anything. do you think these parts as-is without oc will still do the job for my needs? about the video capture card, that's a very good idea (although there's one really bad review in the link you gave) as for the HD - is that SATA2? Now, as for the cooling heat sink, case and floppy, what do you reccomend that will work best with the other parts you listed here? I'll probably order this in a day or two but i'd like to get some more replies and ideas before i do also, I know my way around pcs pretty well and i've installed pci cards myself, but i never actually put a complete pc together, is there a good simple guide online you know of? or do you think i should ask/pay someone else to do it for me? Thanks Ben המחשב הזה יתפקד מצויין לצרכים שלך, וכן זה SATA2. היום מחשבים הם כאלה USER FRIENDLY שכל שימפנזה יכול להרכיב אחד. באופן כללי אני לא מסכים עם ההערות של אינטגרל - ספק כח למערכת הזאת לא צריך להיות מטורף, הוא צריך להיות מתאים, ולכן כל ספק 400W ממוצע שתקנה כאן בארץ יתאים לצרכיך. בארה"ב יש פשוט מבחר ספקים בהספקים גבוהים של יצרנים איכותיים יותר, אבל אין לך צורך ממשי באחד כזה, ולכן אתה יכול לוותר על המשקולת. כמו שאמרתי, השיקול צריך להיות OVERWEIGHT. מאותה סיבה לקנות את הביג טייפון ששוקל קרוב לקילו (825GR) תהיה טעות מרה. עדיף לשלם עוד 10$ ולקנות אותו בארץ. לגבי לוח אם, אני חושב שלוח אם סולידי שיעשה את העבודה זה כל מה שצריך. את כל מה שהאסוס מציע, אם בכלל צריך את זה, ניתן להוסיף אח"כ (אז יש לו HDTV. בשביל מה אתה צריך את זה, הרי קנית כרטיס עם HDTV OUT). כמו שאמרתי, אין בעיה לקנות 7800GT בNEWEGG, אבל אני לא חושב שאתה צריך אחד. בהתחשב בזה שזה מפלצת מתח נוראית, ושאתה לא כזה גיימר, 6800GS שהוא לא בדיוק כרטיס חלש יספיקו לך. גם חבל שזה יבוא על חשבון חלקים אחרים. לגבי 4GB, לדעתי זה טירוף. 2GB זה כבר הרבה מעבר למומלץ. אני גם לא בטוח שאפילו פוטושופ תנצל את זה. אז יהיה לך PAGEFILE בגודל של 2KB. אז מה. דבר אחרון לגבי הביקורות בNEWEGG, הן נכתבות ע"י לקוחות ולכן אינן משקפות דבר. למד להתעלם מהן ולחפש ביקורות השוואתיות באתרי חומרה רציניים. עכשיו - מה אתה צריך לקנות בארץ: № Code Product Price Quant. Summ 0 2443 Citizen/Sony/Alps Black 1.44MB 3,5" FDD 49.00 ¤ 1 49 ¤ 1 4973 Coolermaster CAC-T05 Centurion 5 P/S Not Included Case 398.00 ¤ 1 398 ¤ 2 5499 Enermax 420W EG425P-VE FMA 20/24Pin Power Supply 420.00 ¤ 1 420 ¤ 3 6331 Thermaltake BigTyphoon CPU Cooler 251.00 ¤ 1 251 ¤ 1118 ¤ נלקח מLOGICPC.CO.IL. לגבי מסך, באמת חבל שאי אפשר לקנות בחו"ל. אבל מה לעשות, זה מה יש, וכשתגיע לארץ תתייעץ בפורום המתאים.
פורסם 2006 בפברואר 2420 שנים of course I want to buy a good power source for the system, but isn't it usually a bit heavy? I was going to buy it in Israel when I come back.Another question - how much will the same system cost me in Israel? Will I have no problem if i need to use the warranty on any of these parts? if the difference is not substantial, do you think it's wiser to just buy it in Israel?זה מה שמערכת דומה תעלה בארץ:דגם מחיר כמותIntel Pentium D 920 Dual Core 2.8Ghz 2x2Mb L2 LGA 775 Box 1760 ¤ 1GIGABYTE GA-8I945P-G 665 ¤ 1PQI TURBO DDR2 667MHZ 2048MB DUAL CHANNEL 1280 ¤ 1WD 250GB 7200RPM 16MB SATAII 740 ¤ 1eVGA 6800GS 256MB PCI-E 1200 ¤ 1סה"כ: ¤ 5645 (3 תשלומים)מחיר מזומן: 5475.65מבחינת אחריות - בטח שעדיף לקנות בארץ.לגבי הספקים - תלוי מה תחליט לשים במפרט. כן, בהחלט ניתן לקנות בארץ, רק שדברים מיוחדים כמו ה PC P&C קשה להשיג פה.4 גיגה - היו פה טרדים עם משתמשים כבדים. בהחלט יכול לעזור. כמו גם דיסקים ברייד.לגבי משחקים:hey there. I'm also going to use it for some gaming so I want it to be able to run new games well - but it's the least important thing.ויכנס בתקציב אז למה לא כרטיס טוב יותר? לגבי האסוס - לא רק שיש לו HDTV TUNER שאין לכרטיס מסך שהצעת, יש לו FIREWIRE שכדאי שיהיה למחשב שישמש לעריכה ויכולות האוברקלוק שלו טובות משמעותית למיטב ידיעתי מהגיגבייט שהצעת. גם אם אינו הולך לעשות OC היום, מחר יגלה שזו טעות שלא לעשות זאת עם מעבד כזה. רן (BIODOME) כרגע בודק את אזור ה 4 גיגה עם ה 920 שלו, וההבדל יהיה מהותי ביותר ל 2.8 גיגה. במיוחד לאפליקציות כבדות. לא לשמור את האופציה זו טעות.לגבי ה BT - מסכים. אין צורך להסחב איתו.
פורסם 2006 בפברואר 2420 שנים משמע, אם אתה קונה בניו אג, חסכת למעלה מ-1200 שקל (אינטגרל לא הכליל את כרטיס הטלויזיה).אני חושב שזה אפשרות לקנות 7800GT. שוב, המשמעות של זה זה רק במשחקים שציינת שחשובים לך אבל לא במיוחד.6800GS עולה 1100 שקל בארץ ו180 דולר באמריקה.7800GT עולה 1900 שקל בארץ ו290 דולר באמריקה. (הגרסא שאני חושב שכדאי שתקנה עולה אפילו 2200 בארץ).ההפרש בארץ הוא 800 שקל, וההפרש בחו"ל הוא 500 שקל. יש היגיון לקנות אותו בחו"ל. אתה גם לא תצטרך לשדרג אותו הרבה זמן אם אתה רק גיימר מזדמן. מצד שני, אתה יכול לקנות כרטיס יותר זול, שתשדרג לכרטיס מוצלח אף מה-7800 יותר מוקדם. זה הכל לשקולך. מה שכן, הוא כרטיס מדהים.אם אתה קונה אחד, אני מציע לקנות את הכרטיס של LEADTEK, שמגיע עם OC מהמפעל, חברה מצויינת וכרטיס מעולה:http://www.newegg.com/Product/Product.asp?Item=N82E16814122228
פורסם 2006 בפברואר 2420 שנים משמע, אם אתה קונה בניו אג, חסכת למעלה מ-1200 שקל (אינטגרל לא הכליל את כרטיס הטלויזיה).לפי החישוב שלי, ה 814 דולר, לא כולל את כרטיס הטלוויזיה. כלומר, 814 דולר שזה ~3800 מול 5600, כלומר חסכון של 1800 שקל או 30%. דרך אגב את ה PVR150 אפשר להשיג ב 500 שקל בארץ.
פורסם 2006 בפברואר 2520 שנים מחבר i'm not so sure i'll be buying it in newegg anymore, just because of the warranty issueplus, if custums stop me on my way back i'd end up paying more than it would cost me in israel right?what do you think? i need to decide soon if i want to order it or not
פורסם 2006 בפברואר 2520 שנים i'm not so sure i'll be buying it in newegg anymore, just because of the warranty issueplus, if custums stop me on my way back i'd end up paying more than it would cost me in israel right?what do you think? i need to decide soon if i want to order it or notאין מיסי קניה על חלקי מחשב. מכס תופסים אותך - 16.5 אחוז מע"מ הלכו. אתה עדיין חוסך כ-15%. 15% מתוך הסכום זה עדיין בערך כמעט אלף שקלים, במידה ואתה לא קונה את ה7800GT, אם כן, זה כבר כמעט 1300 שקל, במידה ותופסים אותך.האם זה שווה מבחינת אחריות?יש רכיבים שכן ויש כאלה שלא.אני אישית מאמין שזה שווה את הסיכון, במיוחד לרכיבים כמו הכרטיס מסך והזכרונות, ואולי גם המעבד, אלו עם הפרש המחירים הכי גדול.
פורסם 2006 בפברואר 2520 שנים DUDE GET A DELLdell got a sale on laptopstake a look at e1705you get a dual core proccesor1GB RAM 100 HARDISKa 17 inch ultra sharp screenanda 7800 GO MOBILE video cardthere a coupon that give u 650$ discountPM me ill give it to youand if u take the 3 year warranty you can transfer it to israelit's the best deal right knowyou can see the CPU in toms hardware review,its almost on the same level as the 920
פורסם 2006 בפברואר 2620 שנים מחבר so maybe i should just buy the memory, cpu and video card in newegg?i'm thinking about a laptop i'm just not sure it'll perform that well for graphic design and i need a larger HD and a DVD burner
