פורסם 2006 בפברואר 2320 שנים המעבד הוא טריי.אפשר לקנות GSKILL בנועה ב 490 שקל ולשים קרור בהפרש.לטעמי עדיף ה 6A19 על הסמוראי.
פורסם 2006 בפברואר 2320 שנים המעבד הוא טריי.אפשר לקנות GSKILL בנועה ב 490 שקל ולשים קרור בהפרש.לטעמי עדיף ה 6A19 על הסמוראי.צודק (לא שמתי לב, מצטער) צודק וצודק. אבל הכיוון הכללי הוא שעקרוני, כל השאר זה FINE TUNING.
פורסם 2006 בפברואר 2420 שנים heyi want to buy a computer for similar uses (internet, office, graphic design - photoshop -, multimedia, and gaming (but i'm not a very heavy gamer(.will this pc suggestion fit me as well?another question - i'm in the United Stated right now, would you reccoment buying any parts here or maybe even the entire computer? I've heard newegg.com are considered cheap but i never bought anything from there.ThanksBen
פורסם 2006 בפברואר 2420 שנים heyi want to buy a computer for similar uses (internet, office, graphic design - photoshop -, multimedia, and gaming (but i'm not a very heavy gamer(.will this pc suggestion fit me as well?another question - i'm in the United Stated right now, would you reccoment buying any parts here or maybe even the entire computer? I've heard newegg.com are considered cheap but i never bought anything from there.ThanksBenthe problem with yanks is they usually dont know shit about computer specs, only brand names. the average american wouldnt walk into a wallmart and ask for an intel or AMD PC, he'll just ask for a dell.thats where NEWEGG come in. they're a REALLY cheap, very reliable online store, and i have lots of internet buddies who have bought from them in the past and enjoyed the experience. they're the only viable option for a computer enthusiast in the states. they also have great sales.the comp spec i just provided the other guy is very gaming oriented, and is centered around the vid card. for photoshop and other uses which dont include gaming, i suggest you open your own thread and specifically ask people to build you a custom spec from newegg, given a USD budget and all.g'luck.
פורסם 2006 בפברואר 2420 שנים Here is what i found in newegg.com - what do u think?Qty. Product Description Unit Price Savings Total PriceUpdate Maxtor MaXLine Plus III 7L250R0 250GB 7200 RPM IDE Ultra ATA133 Hard Drive - OEMModel #: 7L250R0Item #: N82E16822144236Remove item from Cart Remove Save Save Move To Wish List $99.00 $99.00Video CardsQty. Product Description Unit Price Savings Total PriceUpdate GIGABYTE GV-NX78T256VB-ED Geforce 7800GT 256MB GDDR3 PCI Express x16 Video Card - RetailModel #: GV-NX78T256VB-EDItem #: N82E16814125009Remove item from Cart Remove Save Save Move To Wish List $296.99 $296.99Memory - SystemQty. Product Description Unit Price Savings Total PriceUpdate GeIL Value 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model GE1GB3200BDC - RetailModel #: GE1GB3200BDCItem #: N82E16820144310Remove item from Cart Remove Save Save Move To Wish List $69.99 $69.99Intel-compatible MotherboardsQty. Product Description Unit Price Savings Total PriceUpdate Gigabyte GA-8I945P-G Socket T (LGA 775) Intel 945P ATX Intel Motherboard - RetailModel #: GA-8I945P-GItem #: N82E16813128294** This item is warranted through the product manufacturer only. what's this?Remove item from Cart Remove Save Save Move To Wish List $98.00 $98.00ProcessorsQty. Product Description Unit Price Savings Total PriceUpdate Intel Pentium D 920 Presler 800MHz FSB LGA 775 Dual Core Processor Model BX80553920 - RetailModel #: BX80553920Item #: N82E16819116237** This item is warranted through the product manufacturer only. what's this?Remove item from Cart Remove Save Save Move To Wish List $258.00 $258.00
פורסם 2006 בפברואר 2420 שנים no man, you're not listening. if you're not a gamer, you have no use for that overpriced video card. you'd much more benefit from 2*1024mb of ram instead. and for instance, you picked an old IDE hard drive instead of a newer SATA2 one. so what i'm saying is, open a new thread, state a budget and the purpuse for the new machine, and we'll put together something specially built for you
פורסם 2006 בפברואר 2420 שנים hey, i sent that reply before i read yours i just opened a new topic so you're invited over there thank you
