מהו צמיג רדיאלי וצמיג לא רדיאלי?
The radial tire was invented by Michelin, a French company, in 1946, but did not see wide use in the United States, the largest market at that time, until the 1970s. This type of tire uses parallel carcass plies for the sidewalls and crossed belts for the crown of the tire. All modern car tires are now radial. In 2005, Michelin was reported to be attempting to develop a tire and wheel combination, the Tweel, which does not use air.
יחי Wikipedia
אני רואה קראת את הכתבה על הצמיגים בYNET...
