Bought a new PC, but no hebrew / Gibrish
Hi!
Sorry for writing in English, but that's the problem... I Bought a new PC with original Windows XP Pro (The men in the store already installed the win for me) but I can't write in hebrew - the Shit+Alt do nothing, if there is hebrew somewhere I see it in Gibrish, and folders with a hebrew name are seen from left to right.
If I go the Control Panel->Regional and Language Options, Hebrew eveb doesn't show there! There is Hungarian but no Hebrew!
BTW, office is still not installed on my PC, maybe that's the prob...
How can I solve this?
Thanks.
Make sure to tick this one and click apply
:P
You may need the WinXP CD for that to work.
After that Hebrew shall appear there...
[attachment deleted by admin]
We haven't finished yet...
Apply the Supplemental Language Support, and set these as following... then re-apply, and restart.
תודה רבה חברים!! הכל עובד מצויין, אני יכול לכתוב (כפי שאתם בטח רואים), אין גיבריש, לא הפוך...
פשוט גאונים, לא הייתי עולה על זה לבד.
תודה רבה! :lol:
