פתחתי MINIDUMP ב-WINDBG.מישהו יכול להגיד לי מה הולך פה?
Microsoft ® Windows Debugger Version 6.5.0003.7
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [F:\WINDOWS\Minidump\Mini112405-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d0000 PsLoadedModuleList = 0x80553420
Debug session time: Thu Nov 24 16:03:46.390 2005 (GMT+2)
System Uptime: 0 days 0:07:40.956
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {b79a7b5e, 0, bf85bda7, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image win32k.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : win32k.sys ( win32k+5bda7 )
Followup: MachineOwner
