מישהו שמע על הלוח אם הבא:Tyan Tomcat K8E (S2865ANRF) Motherboard
וזה המפרט שלו:
Features
Form Factor ATX
Compatibility PC
Chipset NVIDIA nForce4
Compatible Processors AMD Athlon 64, AMD Opteron
Front Side Bus Speed 1000 MHz
Technical Features
Integrated Input/Output Ports USB 2.0 x 6 RJ45 Lan Port x 2 FireWire (IEEE1394a) x 2 Serial Port x 1 PS/2 Mouse x 1 PS/2 Keyboard x 1 Parallel Port (ECP/EPP/SPP) x 1 Floppy Port x 1
Expansion Slots PCI Express x16 x 1 PCI x 4 PCI Express x1 x 2
RAID Support JBOD Support SATA RAID 0 SATA RAID 1 SATA RAID 0+1
Storage Controller Type(s) Serial ATA II x 4
Processor
Socket Type Socket 939
Max supported CPUs qty 1
Memory
Memory Type DDR SDRAM
Number of Memory Slots 4 x DIMMs
Supported RAM speeds 400 MHz 333 MHz
Max Supported RAM 4 GB
Audio / Video
Video Interface PCI Express x16
On Board Graphic Processor ATI Rage XL
Installed Video Memory 8 MB
Integrated Graphic Card Integrated Graphic Card
Audio Output 5.1 Channels Line Out
Integrated Audio Realtek ALC655 AC'97 Audio Codec
Audio Input Microphone Jack 1 x Line In
Video Out Ports 15 Pin D-Sub VGA port x 1
Communication
Networking Type Ethernet, Gigabit Ethernet, Fast Ethernet
Other Features
Other Features Dual Channel Memory Architecture
Fans 1 x 4-pin fan headers 5 x 3-pin fan headers
Chassis Type Desktop
Package Qty 1
Dimensions
Depth 9.6 in.
Width 12 in.
Warranty
Warranty 3 Years
Miscellaneous
Bios Features Plug And Play BIOS DMI2.0 WfM2.0 APM 1.2 ACPI 1.0 PCI 2.3
Power Configurations ACPI/APM Power Management Wake On Ring Header Wake On LAN Header Suspend to RAM Wakeup from Keyboard/Mouse Power-on Mode Control Suspend to Disk (Hibernate)
Regulatory Approval FCC Class B CE FCC Part 15
Bios Type 8 Mbit Flash EEPROM with AwardBIOS
Release Date Q2, 2005
MPN S2865ANRF
Product ID 26924883
http://www.tyan.com/products/html/tomcatk8e.html
TYAN מייצרת לוחות לשרתים,
מה מיוחד בלוח הזה?
יש לו תמיכה רשמית באופטרון 939...
כשברוב הלוחות האחרים, מעדכנים ביוס ופוף....
אני שוקל לרכוש אותו בתור לוח אם למחשב ביתי.
הוא הרי תומך גם במעבדי AMD ATHLON 64
הוא תומך בכל מעבד בסוקט 939
מה מיוחד בו?
לא הרבה
מה אתה מחפש מהלוח שאתה רוצה לקנות?
אוברקלוק?
אחלה קומבינה הלוח הזה
צ'יפסט של NVIDIA עם כרטיס און בורד של ATI
לא כל יום רואים דבר כזה :D
גם נכון
אבל זה Rage XL :\
אי אפשר לתכנן עליו להרבה
שים לב שבדגם שהוא ציין (S2865ANRF)
אין את ה Rage XL משולב
