עידכונים חדשים לנגנים: T10, T20, T30, H10
חברים יצאו אתמול עידכונים חדשים לנגנים:
iriver H10 5/6 GB US
iriver H10 5/6 GB PURE INTL
iriver H10 5/6 GB INTL
iriver T10/20/30 US and INTL
http://iriver.com/html/support/download/sudw_view.asp?idx=736 העדכונים...
אני בספק אם מישהו פה צריך את העדכונים לTים
אבל לH10 צריכים
מה העדכונים מוסיפים?
[Added Features]
1. Interval Repeat (A-B)
- You can set A and B interval by pressing power button during playback.
2. File sort by alphabetic
- Files are displayed by alphabetic on TEXT and PHOTO mode.
3. Indication of current playing song in the browser
- A red arrow is marked in front of the song title.
4. Remembering previously seletected menu.
- It goes back to the previously selected menu/song.
5. Scroll speed control on touch scroll
- Scrolling speed can be accelerated by holding touch scroll for 3~4 secs on browser(MUSIC/BROWSER).
6. On-the-fly Recorded file deletion
- On 'BROWSER', select a file to delete and hold 'Select' button.
Files under AUDIO/TUNER/VOICE folder only can be deleted and files under sub folder can't be deleted.
[improved Features ]
1. It doesn't play files under AUDIO/TUNER/VOICE when playing music on BROWSER mode.
Recorded files can be played in the folder only.
2. The accessing time for 'BROWSER' has been improved.
3. Displays "Shutting down" whenever it powers off.
4. It renames existing file before starting to record when there's a file which has the same file name.
5. The icon for wating is changed to sandglass.
6. It displays "Starting Photoslide" when it starts slide show on PHOTO mode.
7. The maximum number of files on TEXT and PHOTO mode is increased as below.
TEXT : 100 -> 600 files for each folder
PHOTO : 400 -> 600 files for each folder
[Fixed Bugs]
1. Fixed to add songs to the Quicklist on Quicklist playback.
2. Fixed the issue of not scrolling up on certain Text files.
3. Fixed to display Artist and Title information completely without having a break
4. Fixed to display images which are smaller than LCD size(128X128) correctly.
5. Fixed the issue of backlight itself turns on and off.
6. Fixed the issue of backlight timer is set to 5 sec, when switching HOLD ON and OFF, backlight turned off after 10 sec.
7. Fixed the issue of incorrect screen display; showing the previously displayed screen just before LCD turned off about 1 sec before showing the correct/current screen.
8. Fixed the issue of taking long time to power off.
9. Fixed the issue of not shuffling all tracks
*אלה העידכונים לH10 - נראה מצויין.
סופרמן, זה גם משפר את הבעיה שהייתה לך לא?
איטיות בבראווסר
עוד לא עידכנתי - עוד מעט - למרות שאני לא בטוח שזה העידכון לגירסה הINTERNATIONAL אלא לגירסאות הMTP - כלומר אלה שעובדות עם המדיה פלייר.
גם אני מתלבט כי כתוב שזה MTP מצד אחד, ומצד שני כתוב אירופאי :-\
תשאלו במיסטיק ריבר
העידכון הזה הוא רק לגירסאות שמגיעות עם מדיה פלייר - ממש מרגיז :pissed: :pissed: :pissed:
בעע
עד שיצא עדכון כ"כ טוב הוא לא לאירופאי!
