memory for ASUS P4S533-VM
Hi Everybody,
I wanna upgrade my computer's memory. I currently have 512RAM and i thoguht about upgrading it.
I have two questions, first of all should i invest in 1GB or 2GB i understand there is a 100$ difference between the two.
and the second, i understand that i can use PC3200 on this board that will run at 2700. are there any other things that i should know in terms of buffered/unbuffered or ECC/non ECC and so on.
The computer is not for OC.
thanks,
Omer
two memories i thought about:
http://www.newegg.com/Product/Product.asp?Item=N82E16820144321
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440
i buy the memory in the US so if you have suggestions, please include links to sites in the US.
You need standard DDR (unbuffered non ECC).
PC3200 is fine
