נסתי להתקין משהו לut2004 ואני צריך עזרה
אלה ההוראות
1. Put all files with the .INT, .U and .UPL extensions in the \UT2004\System directory.
2. Put the .UTX file in the \UT2004\Textures directory.
3. Run UT2004.
4. Under the Player or Bot voice drop-down menu select "Biehn v2.0".
If you're running a server and want to use this VP, you'll need to make the following changes:
1. Open the UT2004.INI file and place the following under the heading [Engine.GameEngine]:
ServerPackages=Biehn2K4VP2
2. Run the following command to rebuild your server's valid package list:
UCC MASTERMD5 -c *.U
ואת מה שסימנתי לא הבנתי משהו יכול בבקשה לעזור
