איך מעדכנים X5L?
השאלה בכותרת
א. יש לך או שאתה סתם שואל ?
ב. פה יש את העידכון האחרון : http://eng.iaudio.com/zeroboard/zboard.php?id=A02&no=77&bmenu=support
העידכון הזה גורם לX5 לתמוך במצלמות של כנון....קיימים עידכונים קודמים באתר שמעדכנים את הממשק ומתקנים באגים. האחרון :
http://eng.iaudio.com/zeroboard/zboard.php?id=C08&page=1&sn1=&divpage=1&bmenu=download&category=26&sn=off&ss=on&sc=on&select_arrange=headnum&bmenu=download&desc=asc&no=149&bmenu=download
בשני דפי העדכונים יש ללחוץ על DOWNLOAD בסוף ההודעה.
ג. הליך העדכון :
The firmware update must be performed in Recovery Mode when updating from previous firmware to the current firmware . The same rule applies to firmware downgrade when rolling back from the current firmware (ver. 1.30) to an older firmware .
★ Before installing new firmware, existing firmware must be removed from iAUDIO.
There are 2 ways to remove existing from iAUDIO:
Control Panel -> Add/Remove programs -> Remove iAUDIO X5 [ Cowon digital Audio Player]
OR
Start -> Programs -> Cowon System -> Remove
▣ How to update firmware in Recovery Mode
The firmware update must be performed in Recovery Mode when updating from previous firmware to the current firmware . The same rule applies to firmware downgrade when rolling back from the current firmware to an older firmware .
If not in Recovery mode, installation will shut down with the following error message:
Please use Recovery mode to install new firmware! Please visit http://eng.iaudio.com for more detail
Installation steps
1. http://eng.iaudio.com -> click DOWNLOAD -> F/W S/W : iAUDIO X5 Firmware V2.10 . או את הלינק למעלה.
2. Unzip the installation file and execute Setup.exe.
3. Click Agree -> Next -> Finish installing Firmware update program by following the instruction from the installation wizard.
4. Start -> All Programs -> Cowon -> iAUDIO X5 -> Firmware download
5. Remove battery from the iAUDIO X5 . Use USB cable to Connect X5 to a computer while pressing play button on the X5.
6. Keep pressing Play button after a connection is made until windows begin New hardware found wizard.
7. The wizard recognizes X5 in Recovery mode, and brings up the firmware update window on the screen.
8. Click Start to begin installation. Firmware update also includes HDD format, so make sure to back up all your data before installing.
9. Please close all other programs during installation. Press Close to finish installation.
10. Remove USB cable, and confirm the new firmware is updated from the information section in the menu.
*** לא מצאת את הדרך לעדכן את הX5 ספציפית זה כנראה כולל את כל המכשירים של החברה ***
מקווה שעזרתי,
בר.
אני מסתפק בנגן אחד (H340)
חבר שלי שלא מצא בשום מקום איך להתקין והסתבך כאילו זה לפרק ולהרכיב את הנגן
אז ביקש ממני לשאול בפורום
אם הייתי יכול הייתי קונה X5L אבל יש לי כבר H340
למה חבר שלך חבש שצריך לפרק את הנגן בשביל לעדכן אותו ?????????????????????????????????????????????????????????????
חחחחחחחחחחחח לא הבנת אותי
הוא כל כך הסתבך עם העדכון של הX5L כאילו הוא צריך לפרק ולהרכיב נגן יענו הסתבך מאוד
עדיין לא הבנתי למה הוא חושב שהוא צריך לפרק אותו ? ? ?
וואה עליך :kopfpatsch:
אני מסביר לך שהבן אדם מסתבך עם התקנה של עדכון כאילו הוא מפרק ומרכיב את הנגן יענו באותה רמת קושי יענו הסתבכות מה יש להבין?
לא למדת בספרות מה זה דימוי???
