קניית לוח חדש
I need to buy new M.B
I need it to have LGA775 socket P4 3Ghz 64 bit  1M
Also I need to have support DDR 1
And AGPx8
Also I need to know if this M.B have unlock cpu multiplier
Reg.
this MB looking good
but it can open the mul.
i have DDR1 PC4000
and i want to overclocking
the mem and the
CPU
the budget is not the problem
reg.
about the multipilier i dont know if you can change it
but to do oc to the cpu is not a problem with this memory
tankyou
can you astimeit the oc i can get
