ANTEC PlusView 1000 AMG Metallic Gray SOHO File Server
Hello I wanted to know the sizes of the case - ANTEC PlusView 1000 AMG Metallic Gray SOHO File Server if some one has it I want to make sure that its can get in my table thanks
חשבת לחפש באתר החברה?
גוגל?
אני בטוח שתמצא.
Emm I forgot to say I am not speaking Hebrew or whatever if you can translate it, its will be better
Translation:
Have you thought about searching Google or the firm site first before asking here?
I am sure you will find an answer.
I found for you the size of the case but next time take Xploiter advice and search for it first  :xyxthumbs:.
Dimensions (WxDxH): 20.6 cm x 47.2 cm x 52.3 cm
Weight: 12.2 kg
Thank tov tov and xploiter but I searched in Google and I found something but the size wasnt real and I right about it you gave an other sizes
