looking for a good OC memory for 1400nis
[ltr]recently I bought 1Gb of BH-5 in 2 sticks of 512mb each. now for some reason, they just doesn't want to run even close to stock (stock is 433 2.5-4-4-7 2.8v) on my NF7-S. right now I'm running them at DDR 333Mhz 2-3-3-10 at 3.3v and it's not even barely stable. FYI I'm running a marlin D25 bios, which helped a bit but still not even close to stock.
I guess it's just a compatibility issue with the NF7 (those are the new BH-5 from 2005). anyways the store is willing to replace them with something else and I don't know what to take. so what I'm looking for is a 1Gb OC memory (512x2) for 1400 nis ,1500 max. can't be BH-5 cause it doesn't work.
tnx in advance.[/ltr]
יש לך 2 אפשרויות מבוססות TCCD
OCZ Platinum Rev.2 כמו שאמר לפניי יוני
PQi Turbo Black Copper TCCD
[ltr]How about those?
my vdimm mod can get to 3.3-3.35v. will they be good enough for my? I'm looking for at least DDR450 at no more than 2-3-3-10.
btw what chips do they use?
now since I bought it at pandas, it needs to be available in pandas =\[/ltr]
EL DDR PC3200 DC Gold VX (2-3-3-8 @2.6V | 2-2-2-8 @3.2V) --chip--> Windond UTT (relabeled as OCZ Voltage eXtreme) ~ Brainpower PCB
במחיר הזה אתה משיג OCZ Platinum Rev.2 שהם TCCD
לא צריך הרבה מתח והם יעשו 225 לפי דעתי גם על 2-2-2 או 2-3-2
[ltr]thank you very much so far, are there any other possibilities?
and has anybody seen a review of this memory on an nForce2 platform?[/ltr]
דווקא זכרונות BH5 רגילים וBH5 UTT מסתדרים יפה מאוד עם nForce2 ונותנים אוברקלוק יפה מאוד , דווקא לזכרונות TCCD יש בעיות תאימות (מבחינת ניצולת של מהירות ותזמונים) עם nForce2 .
תחפש זכרונות מבוססים על Samsung TCCC / Hynix BT-D43 or CT-D5.
תנסה ביוסים D26 ו D27 של מרלין.
[ltr]SubX, does it apply to '05 BH-5 UTT? because I had 3 or 4 different dimms and none of them worked close to it's stock speed even when highly overvolted and I tried them on 3 "different" platforms, NF7, NF7-S v2, AN7.
edit: btw, I also tried D26, that didn't help that much either.[/ltr]
בדקתי BH-5 UTT חדשים על הNF7 שלי והגעתי ל480-486MHZ ב2.9V (ואני בטוח שהם היו עוברים את ה500MHZ בלי מאמץ אם היה לי אפשרות לתת להם מתח גבוה יותר)
אולי קיבלת זכרונות לא משהו.
[ltr]SubX, could it be that this specifc twinmos speed premium BH-5 doesn't work well on my NF7-S?
anyway, I got 10 minutes to decide. any other ideas?
tnx. [/ltr]
דווקא הBH5 UTT שבדקתי על הלוח שלי לאחרונה היה Twinmos Speed Premium.
אם זה לפלטפורמה nForce2 ואינך בכיוון של זכרון מבוסס BH5 לך על ההצעות שאמרתי לך בהודעות קודמות.
[ltr]well it turns out they need to send it to the lab to check it's ok, before they'll replace it/give me store credit, so I have untill the end of the week to decide what to take.
anyways I never heard of those specific hynix chips, what memories use them? and about TCCC the seller at the store, a very nice dude named dima, says there are no TCCC memories available in israel, but he said there might be TCC5 soon or something like that.[/ltr]
[ltr]first of all, sorry for the bounce, but this is very important and there has been an update. the OCZ plat rev 2 priced has jumped by more than 200 nis which moves them waaay out of my price range. I'm thinking about the Kingston HyperX DDR400, I read it is also TCCD, can someone confirm?
if you have a better idea please let me know, but it has to come from pandas (=\) because I have store credit there and they won't give me my money back =[.
edit: the HyperX I'm talking about are those[/ltr]
BH5/UTT יהיו לך הכי טובים, בציר טוב יעשה לך 500 מגה הרץ בקלות על 3.2V-3.3V
הוא טוען שBH5 לא עובדים כמו שצריך על הלוח שלו , לכן הוא צריך זכרונות עם צ'יפים אחרים.
TCCD כמובן לא ינוצל ולא יפיק את מירב הביצועים על הלוח הזה אפילו במהירויות/תזמונים מקבילים בין nForce2 ל nForce3/4 , אך עדיין יכולים לתת את התמורה.
