צריך חוות דעת על המערכת הזאת
אז ככה אני חדש כאן אנשים ואני מאוד השמח לקבל דעה לגבי המחשב שלי ואים יש לי צורך לשדרג משהו אז ככה
אני מקווה שהצלחתי להעתיק טוב--------[ EVEREST Home Edition © 2003, 2004 Lavalys, Inc. ]-----------------------------------------------------------
Version EVEREST v1.10.106/he
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer EECDDF4RQN3V2X2 Generator
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2005-06-03
Time 19:39
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 2
Internet Explorer 6.0.2900.2180
DirectX 4.09.00.0904 (DirectX 9.0)
Computer Name EECDDF4RQN3V2X2
Motherboard:
CPU Type Intel Pentium 4HT, 2800 MHz (14 x 200)
Motherboard Name Unknown
Motherboard Chipset VIA VT8763 Apollo PT800
System Memory 512 MB (DDR SDRAM)
BIOS Type Award (01/27/04)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port Printer Port (LPT1)
Display:
Video Adapter GeForce FX 5200 (128 MB)
Video Adapter NVIDIA GeForce FX 5200 (128 MB)
3D Accelerator nVIDIA GeForce FX 5200
Monitor KDS Radius S-3F (BBA33012079)
Multimedia:
Audio Adapter Creative EMU10K1 SB Live! Audio Processor
Storage:
IDE Controller VIA Bus Master IDE Controller
SCSI/RAID Controller D347PRT SCSI Controller
Floppy Drive Floppy disk drive
Disk Drive WDC WD400EB-00CPF0 (37 GB, IDE)
Disk Drive WDC WD400BB-00DEA0 (37 GB, IDE)
Optical Drive Generic DVD-ROM SCSI CdRom Device
Optical Drive HL-DT-ST CD-ROM GCR-8520B (52x CD-ROM)
Optical Drive HL-DT-ST CD-RW GCE-8526B
SMART Hard Disks Status OK
Partitions:
C: (FAT32) 38152 MB (15181 MB free)
F: (NTFS) 38154 MB (31692 MB free)
Input:
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Network:
Network Adapter Realtek RTL8139 Family PCI Fast Ethernet NIC (172.25.109.246)
Network Adapter VIA Rhine II Fast Ethernet Adapter (192.168.0.1)
Network Adapter WAN (PPP/SLIP) Interface (62.0.156.105)
Peripherals:
Printer Microsoft Office Document Image Writer
USB1 Controller VIA VT83C572 PCI-USB Controller
USB2 Controller VIA USB 2.0 Enhanced Host Controller
USB Device Logitech QuickCam Express
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Vendor Phoenix Technologies, LTD
Version 6.00 PG
Release Date 01/27/2004
Size 256 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD
Supported Standards DMI, APM, ACPI, PnP
Expansion Capabilities ISA, PCI, AGP, USB
[ System ]
System Properties:
Manufacturer VIA Technologies, Inc.
Product PT800-8237
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Product PT800-8237
[ Chassis ]
Chassis Properties:
Chassis Type Desktop Case
[ Memory Controller ]
Memory Controller Properties:
Error Detection Method None
Error Correction None
Supported Memory Interleave 1-Way
Current Memory Interleave 4-Way
Supported Memory Speeds 70ns, 60ns
Supported Memory Types SPM, EDO
Supported Memory Voltages 5V
Maximum Memory Module Size 32 MB
Memory Slots 3
[ Processors / Intel Pentium® 4 ]
Processor Properties:
Manufacturer Intel
Version Intel Pentium® 4
External Clock 200 MHz
Current Clock 2800 MHz
Type Central Processor
Voltage 1.4 V
Status Enabled
Upgrade ZIF
Socket Designation Socket 478
Manufacturer Intel
Voltage 1.4 V
Status Enabled
Upgrade ZIF
[ Caches / Internal Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 20 KB
Installed Size 20 KB
Supported SRAM Type Synchronous
Current SRAM Type Synchronous
Socket Designation Internal Cache
Cache Properties:
Type Internal
Status Enabled
Maximum Size 20 KB
[ Caches / External Cache ]
Cache Properties:
Type External
Status Enabled
Maximum Size 512 KB
Installed Size 512 KB
Socket Designation External Cache
Cache Properties:
Type External
Status Enabled
Maximum Size 512 KB
[ Memory Modules / A0 ]
Memory Module Properties:
Socket Designation A0
Speed 60 ns
Installed Size Not Installed
Enabled Size Not Installed
[ Memory Modules / A1 ]
Socket Designation A1
Speed 60 ns
Installed Size 256 MB
Enabled Size 256 MB
[ Memory Modules / A2 ]
Socket Designation A2
Speed 60 ns
Enabled Size 256 MB
[ Memory Devices / A0 ]
Memory Device Properties:
Form Factor DIMM
Device Locator A0
Bank Locator Bank0/1
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
[ Memory Devices / A1 ]
Form Factor DIMM
Size 256 MB
Device Locator A1
Bank Locator Bank2/3
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
[ Memory Devices / A2 ]
Form Factor DIMM
Size 256 MB
Device Locator A2
Bank Locator Bank4/5
Manufacturer None
Serial Number None
Asset Tag None
Part Number None
[ System Slots / PCI0 ]
System Slot Properties:
Slot Designation PCI0
Type PCI
Usage Empty
Data Bus Width 32-bit
Length Long
[ System Slots / PCI1 ]
Slot Designation PCI1
Type PCI
Usage In Use
Length Long
[ System Slots / PCI2 ]
Slot Designation PCI2
Type PCI
Usage In Use
Length Long
[ System Slots / PCI3 ]
Slot Designation PCI3
Type PCI
Usage Empty
Length Long
[ System Slots / AGP ]
Slot Designation AGP
Type AGP
Usage Empty
Length Long
[ Port Connectors / PRIMARY IDE ]
Port Connector Properties:
Internal Reference Designator PRIMARY IDE
Internal Connector Type On-Board IDE
External Connector Type None
[ Port Connectors / SECONDARY IDE ]
Internal Reference Designator SECONDARY IDE
[ Port Connectors / FDD ]
Port Type 8251 FIFO Compatible
Internal Reference Designator FDD
Internal Connector Type On-Board Floppy
[ Port Connectors / COM1 ]
Port Type Serial Port 16450 Compatible
Internal Reference Designator COM1
Internal Connector Type 9 Pin Dual Inline (pin 10 cut)
External Connector Type DB-9 pin male
[ Port Connectors / COM2 ]
Internal Reference Designator COM2
[ Port Connectors / LPT1 ]
Port Type Parallel Port ECP/EPP
Internal Reference Designator LPT1
Internal Connector Type DB-25 pin female
External Connector Type DB-25 pin female
[ Port Connectors / Keyboard ]
Port Type Keyboard Port
Internal Reference Designator Keyboard
Internal Connector Type PS/2
External Connector Type PS/2
[ Port Connectors / PS/2 Mouse ]
Port Type Mouse Port
Internal Reference Designator PS/2 Mouse
[ Port Connectors / USB0 ]
Port Type USB
Internal Connector Type None
External Reference Designator USB0
[ Port Connectors / AUDIO ]
Port Type Audio Port
External Reference Designator AUDIO
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Northwood HyperThreading
CPU Stepping D1
Engineering Sample No
CPUID CPU Name Intel® Pentium® 4 CPU 2.80GHz
CPUID Revision 0F29h
CPU Speed:
CPU Clock 2812.70 MHz (original: 2800 MHz)
CPU Multiplier 14.0x
CPU FSB 200.91 MHz (original: 200 MHz)
Memory Bus 167.42 MHz
CPU Cache:
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ATC, Full-Speed)
Motherboard ID 01/27/2004-PT800-8237-6A6LXJ1AC-00
Chipset Properties:
In-Order Queue Depth 12
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 2T
RAS Active Time (tRAS) 7T
SPD Memory Modules:
N 256 MB PC3200 DDR SDRAM (CL 3.0 @ 200 MHz) (CL 2.5 @ 166 MHz)
Nanya M2U25664DS88B3G-5T 256 MB PC3200 DDR SDRAM (CL 3.0 @ 200 MHz) (CL 2.5 @ 166 MHz)
BIOS Properties:
System BIOS Date 01/27/04
Video BIOS Date 05/05/03
Award BIOS Type Phoenix - Award WorkstationBIOS v6.00PG
Award BIOS Message V.PT800DBP/PT800DBZ A03 01-27-2004
DMI BIOS Version 6.00 PG
Graphics Processor Properties:
Video Adapter nVIDIA GeForce FX 5200 (Inno3D Tornado GeForce FX 5200)
GPU Code Name NV34 (AGP 10DE / 0322, Rev A1)
GPU Clock 270 MHz
Memory Clock 165 MHz
Sensor Properties:
Tsystem 30 °C (86 °F)
Tcpu 49 °C (120 °F)
Fcpu 3668 RPM
Vcore 1.49 V
Vio 3.31 V
--------[ Power Management ]--------------------------------------------------------------------------------------------
Power Management Properties:
Current Power Source AC Line
Battery Status No Battery
Full Battery Lifetime Unknown
Remaining Battery Lifetime Unknown
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type Winbond W83697HF
Sensor Access ISA 290h
Temperatures:
Motherboard 30 °C (86 °F)
CPU 49 °C (120 °F)
Cooling Fans:
CPU 3668 RPM
Voltage Values:
CPU Core 1.47 V
+3.3 V 3.26 V
+5 V 5.03 V
+12 V 11.92 V
-12 V -12.28 V
-5 V -5.35 V
+5 V Standby 4.90 V
VBAT Battery 3.28 V
Debug Info 5C 00 CC BB C4 20 2F 1E FF 2E FF F2 (01)
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: VIA VT8763 PT800 Chipset - System Controller
Offset 00: 06 11 68 31 06 00 30 22 82 00 00 06 00 08 00 00
Offset 10: 08 00 00 E8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 06 11 68 31
Offset 30: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 19 88 80 82 44 10 00 1B 39 88 80 82 44 00 00
Offset 50: A0 F2 EB 88 80 C4 20 20 0E E0 00 00 10 10 20 20
Offset 60: 40 AA 00 20 66 5F 00 98 C2 AD 43 D0 01 C6 00 00
Offset 70: 82 C8 EE 01 C0 01 50 08 01 00 00 00 00 00 00 06
Offset 80: 02 C0 35 00 0B 0A 00 1F 02 0B 00 00 18 00 00 00
Offset 90: 80 01 00 00 30 0F 01 00 00 20 02 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 7F 00 1B 00 47 46 46 02 8B A4 6A 0A 00 00 00 8C
Offset C0: 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 10 00 78 22 11 22 11 47 38 52 00
Offset E0: 00 00 00 00 00 FF 69 32 9A 77 9A 9A BA 9A 41 80
Offset F0: 00 00 24 00 00 00 82 00 00 C0 24 80 00 04 00 00
B00 D01 F00: VIA AGP Controller
Offset 00: 06 11 98 B1 07 01 30 02 00 00 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 20 22
Offset 20: 00 EC F0 ED 00 E0 F0 E7 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 0E 00
Offset 40: A3 C7 E2 44 35 72 98 B1 00 00 00 00 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 01 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D09 F00: Realtek RTL8139 Fast Ethernet Adapter
Offset 00: EC 10 39 81 05 00 90 02 10 00 00 02 00 20 00 00
Offset 10: 01 90 00 00 00 00 00 EE 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 20 40
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D0A F00: Creative EMU10K1 SB Live! Audio Processor
Offset 00: 02 11 02 00 05 00 90 02 0A 00 01 04 00 20 80 00
Offset 10: 01 94 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 11 67 80
Offset 30: 00 00 00 00 DC 00 00 00 00 00 00 00 13 01 02 14
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 06
B00 D0A F01: Creative Game Port
Offset 00: 02 11 02 70 05 00 90 02 0A 00 80 09 00 20 80 00
Offset 10: 01 98 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 11 20 00
Offset 30: 00 00 00 00 DC 00 00 00 00 00 00 00 00 00 00 00
B00 D0F F00: VIA VT8237 PCI-ISA Bridge - DriveStation SATA RAID Controller
Offset 00: 06 11 49 31 07 00 90 02 80 00 04 01 00 20 80 00
Offset 10: 01 9C 00 00 01 A0 00 00 01 A4 00 00 01 A8 00 00
Offset 20: 01 AC 00 00 01 B0 00 00 00 00 00 00 06 11 49 31
Offset 30: 00 00 00 00 C0 00 00 00 00 00 00 00 0A 02 00 00
Offset 40: 23 03 F1 44 06 AF 00 00 10 82 05 03 00 00 00 00
Offset 50: 00 00 00 00 00 00 05 05 00 10 10 00 05 00 10 00
Offset 70: 00 00 00 00 00 00 00 00 01 00 01 00 11 00 00 00
לא יכלת פשוט לרשום איזה חלקים יש לך במחשב?!
אני לא כול כך מבין בשביל לפרט מצטער אים עשיתי בלאגן
תרשום מעבד ,לוח ,כרטיס מסך ,זכרון ,מארז ספק ,מסך ציוד היקפי ,דיסק קשיח צורבים למיניהם...
הלוח אם שלי זה VIA VT8763 Apollo PT800
זיכרון 512ddr
מעבד Intel Pentium 4HT, 2800 MHz (14 x 200
כרטיס מסך fx5200 128
כרטיס קול קריטיב 5.1 לייב
שני ארדיסקים של 40 גיגה 7200
צורב lg
סידי רום רגיל
מארז atx
ספק רגיל
רמקולים altec 2+סבופר
מסך 17 אינץ lcd kds
מקווה שזה ברור עכשיו
ותודה על העזרה שתבוא
מה השימושים העיקריים שלך במחשב?
כי אם זה משחקים אז אתה חייב להחליף כרטיס מסך.
מאיפה הבאת את הלוח הזה?אפילו באייבורי לא מקבלים לוח כזה.
ספק ג'נרי.
איזה חברה המסך?
מעבד סבבה.
תשקול קניית סטיק נוסף של חצי גיגה ,זול מאוד עכשיו.
על המסך רשום
kds radus
בקשר ללוח אז לפי התגובה שלך הוא לא טוב?
ומה זה לקנות סטיק לא בנתי?
השימושים שלי זה אולי משחק שניים אבל בעיקר גלישה חיטוטים באינטרנט
אז תשאר עם מה שיש.
טוב תודה על העזרה ודרך אגב אחלה אתר ופורם התיחסות יפה ומהירה
אחלה תמשיכו ככה
שמחתי לעזור :xyxthumbs:
