G4 Ti4400 The device culdnot start (code 10)
Hi 2 All
Im using Gigabyts 8EIXP mobo with P4 2.2Ghz @ 3Ghz with 756Mb Kingston
DDR333 Ram
A SoundBlaster LIVE! 5.1 And MSI GeForce 4 TI4400 with 128Mb DDR Ram + VIVO
card on WinXP Pro.
Lateli im having a problem with the G4 Vcard, once in a wail wan I reboot
the system my G4 Vcard is not loaded by the os, it is being recognized by
the os but there's an yellow " ! " mark on the card in the device manager
and the error code it displaying is : " The device could not start error
code 10 ".
and nothing I do to fix this like changing the pc profile from: ACPI
UniProccesor PC to: Standard PC
or Ivan Giving the card an assigned IRQ from the mobo BIOS and also
disabling almost every serial,parallel,usb,firewire ports and taking out
every other card there is on board but it don't work.
Im using Nvidia Detonator XP 29.40 and also tray the new 30.30 but nothing
still.
The only thing that works is reinstalling the windows xp pro from the
beginning and its stays like that until I reboot the system...
BTW I tray to do all thus fixing under the original cpu speed and not
overcooked!
PLS HELP!
10x a haead
a) improve your spelling
b)it's prolly a driver thing, try getting the latest drivers/bios from the msi website
אל תכתוב בכזו אנגלית, זה נוראי..
אמרת שזה עושה את גם בלי האוברקלוק?
אז זה בטח דרייברים.
תנסה את אלו מהאתר של MSI אולי..
(ד"א מה הקירור והמעלות שלך?)
