זכרון OCZ VX GOLD PC4000 ובעיית החום הנוצר
לאחר שראיתי את הביקורת הזו על ה-OCZ 1GB PC4000 (2x512MB/500MHz) EL DUAL CHANNEL DDR MEMORY KIT GOLD VX:
http://www.anandtech.com/memory/showdoc.aspx?i=2369&p=12
נראה שהוא יהיה אידיאלי בזיווג עם הDFI ULTRA-D שרכשתי כאן בארהב.
אמנם לא TCCD אבל כמצוטט:
"In the end, OCZ VX Gold is the best performing memory that we have tested on the Athlon 64 platform. At the same speed and same timings, it significantly outperforms any other memory that we have tested on A64. VX does not run at the fastest memory speeds that we have found in our benchmarks - quite a few memories based on Samsung TCCD or Hynix memory chips reach significantly higher speeds than the DDR538 of OCZ VX Gold. However, at DDR534 2-2-2-6 timings, no memory that we have tested outperforms VX. VX is so fast that 533 actually outperforms memory that have achieved DDR600 or more in our memory tests."
לא נראה לי שאצטרך יותר בזמן הקרוב שכן אינני מתכנן להתפרע יותר מזה עם האוברקלוקינג אם בכלל אבל אם מישהו חושב אחרת אשמח לשמוע.
שאלה אחת. בהצעת המחיר הזו:
http://www.atacom.com/program/print_html_new.cgi?cart_id=8658447_65_105_228_244&Pagecode=SEARCH_ALL&Item_code=MEDD_OCZT_AG_G1&USER_ID=www
כתוב:
"OCZ Gold Series EL PC-4000 with Voltage eXtreme technology is a revolutionary line of memory designed to pursue a new level of DDR performance. The PC-4000 Gold VX is made to operate above the traditional memory voltage to increase speed and stability to ultimately allow the memory to thrive under high voltage. Memory performance increases with voltage, but unfortunately with many traditional modules this can significantly reduce stability and increase the potential for module damage. Unlike typical memory, VX DDR performs best at an above average voltage, and better and better as voltage is increased, all without any adverse affects to stability. Running at 3.3 volts, the PC-4000 Gold VX is capable of blistering timings of 2-2-2!"
שאלתי: האם בטמפרטורות במתח הזה יהיה צורך בקירור נוסף במארז כמו זה למשל?
http://www.noacomp.co.il/product.asp?productid=3088
בתודה מראש.
ה vx מצויידים בגופי קירור אבל זה די פשוט מתח = ביצועים = חום = יכול להרוג את הזיכרון ואת הלוח.
את הביצועים הטובים שביותר תקבל עם מתח של 3.4v , הבעיה שלא רק הזיכרון מתחמם מאוד, יש לך על הלוח בקר קטן שנקרא pwmic שהוא מעביר את
המתח לזיכרונות, ברגע שתרצה להגיע למתחים גבוהים אתה תצטרך להזיז גמפר כדי שהלוח יקח מתח מה 5v במקום ה 3.3v ואך שתעשה את זה ה pwmic הזה יתחיל להתחמם למרות שיש עליו וזה ממש ממש לא בריא.
עצותי אם אתה מגיע למתחים האלו:
1) לדאוג באמת שה vx יקבלו איורוור שיצנן אותם .
2) לדאוג לקירור הולם של ה pwmic
ואם אתה לא מגיע ל מתחים האלו ועובד עד מתח של ~ 3.1v אין צורך בקירור נוסף.
לי יש את ה ADATA 500 MHZ ויטסטה ובמתח של 2.95 הם מתחילים להתחמם מאוד בכול מקרה עדיף לצנן את זיכרון תמיד אבל לא חוב אם אתה במתחים שפויים .... ( משהו שלא יקרה כשיש ל VX או כשהם בידיים של קופרה או the byter .....(זאתי מחמאה ...))
תודה רבה על המידע. נראה לך שהקרור שציינתי או דומה לו יכול לעשות את העבודה או שאצטרך אוורור ישיר הן על הזכרונות והן על הpwmic?
הקירור שנתת בלינק לנועה הוא קירור למעבד ..... :nono:
אתה פשוט צריך לכוון איכשהו איזה מאוור לכיוון של הזיכרון ועל הדרך שיפזר מעט אויר לכיוון ה pwmic ...... פשוט מאוורר רגיל ואפשר לשים אותו גם על 7 וולט ...
תודה. נראה שקרור הולם יהיה אחת מדאגותיי ואשתדל למצוא מדריך לעניין.
אני רואה שאתה מסתבך בעצמך יותר מידי!!!! פשוט רק לכוון מאוורר רגיל נורמלי ופשוט לכיוון הרכיב וגם על הזיכרון
קופרה - תעשה טובה לידידנו ותעלה תמונה על איך מכוונים מאוורר לכיוון ה pwmic והזיכרון על ה DFI ..........
;D
[attachment deleted by admin]
תודה רבה על התמונה וההפנייה לקולר :-)
