Need help in configuring home net...
Ok, i connected the internet through crossed cable, both ethernet cards enabled with yellow led.
What am i suppose to do now ? i have no idea...
please be specific if you can cause i really have NO IDEA about it !
Thanks a lot !
what's your OS?
If you have Win XP just run the network wizard on both of your pcs.
Yes, I am using the XP.
where is the network wizard anyway ? and what should i exactly choose in the wizard ?
Ok, thats great guide.
But how can i permit the net in the Sygate Firewall ?
Ok, sorry for the bounce !
ITS WORKING !
Just two questions.. I wrote only one IP adress in my (the host comuter) computer and thats it and everything works, internet in both computers.
Just the first IP adress ! Is that ok ??? cause i saw in the sticky couple adresses.
I need to write the other Ip's on the second computer or its enough just one in my computer and i forget to say that the adresses are not match as they in the guide... same Ip adress for both computers... ?
Btw, what should i choose in the next manu ? (picture), is that ok ?
sorry for the bad english... i am pretty hurry right now....
[attachment deleted by admin]
נראה בסדר.. לגבי ה IP אם זה עובד לא חובה, למרות שאני מעדיף לדעת מה IP אז אני קובע אותם ישירות (יכול להיות שהמחשב השני מקבל את ה IP משרות DHCP של המודם או משהו).
What about the DNS ? is that important to define ?
אם האינטרנט עובד, הוא בטח לקח את ההגדרות אוטומתי מהמחשב השני / המודם... (אחרת האינטרנט לא היה עובד).
I defined my IP as automatic... is that ok ? - the net is still working.
EDIT:
I have another problem, i am using barak013 dialer and its kind of problematic cause i cant connect while both computers are connected.
So i need to disconnect from the home net, connect with my own comp and just then to connect the second comp.. what do you think how can work with the dialer & the home net ?
Thnx ! :)
איך הרשת הביתית שלך מחוברת ?
You didnt read the thread ??
2 ethernet cards with crossed cable
ואללה... התכוונתי בכלליות, גם איך המודם מחובר, לכרטיס רשת נפרד באחד מהמחשבים או מה...
My comp connected directly to the modem with USB cable, and the connection between both net computers with ethernet + crossed cable.
הבנתי, טוב, אין לי נסיון עם המודמי USB האלו...
