אין קול במחשב ... מיואש ניסיתי כבר הכל!!!
crap, can't write in hebrew..
anyways.. go to my computer -> properties -> hardware -> device manager
and see there if there is something with a '!' on it and its yellow (should be device emulator or something..(
if you do have something like that, what you should do is just run windows restore service and restore to the last date you had sound.
hope I helped :P
תנסה להשתמש באיזה LIVECD של LINUX כמו KNOPPIX ולראות אם הוא מזהה את הכרטיס טוב או לא..
