איום התאבדות
אם מישהו לא מביא לי את הדבר הבא למגש אז אני קופץ מהגג שח עזריאלי בלי נדר
Cases (Computer Cases, ATX Form)
RAIDMAX Samurai Black ATX Mid tower Case With 450W PSU, Model "ATX-901WBP" -RETAIL
Item# N82E16811156173
Status: In Stock
Save to Buy Later
Remove Item
$132.50
$132.50
Fans, Heatsinks (Case, CPU, Chipset)
ZALMAN RESERATOR 1 Fanless Water Cooling System(Reservoir+Radiator+Water Pump) -RETAIL
Item# N82E16835118111
Status: In Stock
Save to Buy Later
Remove Item
$238.99
-$20.00
Instant Rebate
$238.99
-$20.00
Instant Rebate
**This item may only be returned for a replacement of the same make/model.
Masscool Hard Disk Cooler, 130 x 100 x 17 mm, Model "4B02S4"
Item# N82E16835150005
Status: In Stock
Save to Buy Later
Remove Item
$3.19
$6.38
Enermax Whispersys System Exhaust Blower (Slot fan), Model "WS-8SLFS"
Item# N82E16835888003
Status: In Stock
Save to Buy Later
Remove Item
$4.99
$4.99
Hard Drives
Fujitsu 147GB 15,000RPM Ultra SCSI320 80pin Hard Drive, Model MAU3147NC, OEM
Item# N82E16822116154
Status: In Stock
Save to Buy Later
Remove Item
$879.00
$879.00
Maxtor MaXLine III 300GB 7200RPM SATA Hard Drive, Model 7B300S0, OEM Drive Only
Item# N82E16822144363
Status: In Stock
Save to Buy Later
Remove Item
$209.00
$209.00
Memory (System Memory)
OCZ Performance Series Dual Channel Kit 240-Pin 2GB(1GB x 2) DDR2 PC2-5400, Model OCZ26672048PFDC-K -RETAIL
Item# N82E16820227011
Status: In Stock
Save to Buy Later
Remove Item
$533.00
$533.00
Monitors - LCD Flat Panel
SAMSUNG 915N-Black 19" LCD Monitor with 8ms Response Time -RETAIL
Item# N82E16824001185
Status: In Stock
Save to Buy Later
Remove Item
$409.00
$409.00
**This item is warranted through the product manufacturer only.
LG Electronics L1980U 19" LCD Monitor -RETAIL
Item# N82E16824005034
Status: In Stock
Save to Buy Later
Remove Item
$579.00
$579.00
Motherboards - AMD
DFI "LANPARTY nF4 SLI-DR" NVIDIA nForce4 SLI Chipset Motherboard For AMD Socket 939 CPU
Item# N82E16813136151
Status: In Stock
Save to Buy Later
Remove Item
$210.00
$210.00
Processors
AMD Athlon 64 FX-55, 1MB L2 Cache, 64-bit Socket 939 Processor - OEM
Item# N82E16819103492
Status: In Stock
Save to Buy Later
Remove Item
$815.00
$815.00
Sound Card
Creative Labs Sound Blaster Audigy 4 Pro PCI Sound Card, Model "SB0380" -Retail
Item# N82E16829102181
Status: In Stock
Save to Buy Later
Remove Item
$286.00
$286.00
Speakers
Logitech Z-5500 5.1 Digital Speaker System w/Digital Hardware Decoder -RETAIL
Item# N82E16836121120
Status: In Stock
Save to Buy Later
Remove Item
$269.99
$269.99
Video Cards
Leadtek nVIDIA GeForce 6800 Ultra Video Card, 256MB GDDR3, 256-Bit, HDTV-Out/Dual DVI, PCI-E, Model "PX6800Ultra" -RETAIL
Item# N82E16814122214
Status: In Stock
Save to Buy Later
Remove Item
$519.00
$1,038.00
$5,590.85
אמממ... קפוץ ?!
בהצלחה, תגיד לנו איך היה :smile1:
מה אכפת לכם תלכו להודו קחו מכל הודי שקל (תגידו שזה בשביל רווחת הפרות) אם אתם עושים את זה אתם מקבלים חצי
קפוץ אח שלי
נקיון מדרכה עלי
אל תשכח לקחת איתך מצלמת וידאו :silly:
תקנו לי ואני אקח
LOL זה בטוח הולך לOGRISH.. רק תן סימן מתי לבוא עם המצלמה ?!
:spam:
מיד לאחר המפגש
קודם תשיג ארנב, אחרי זה נדבר :smile1:
בחור יש לך שם דיסק סקאזי בלי בקר
תחליף אותו ונראה מה נצליח לסדר
בהרבה מקומות בהודו 60שקל זה התשלום החודשי על עבודה...
תתאבד עוד אף אחד לא מת מזה....
גם כן.....מכירים את כל האלה שאומרים לכם קנו לי מאייבך 62 עם כל התוספות או שאני מתאבד?
אני חושב שעל ת'רדים כאלה צריך לתת באן
למען יראו ויראו
:P
