פורסם 2005 במרץ 1121 שנים for some reason alt+shift doesn't change the language as it used to. i can only do it using ctrl+shift, but it also changes the writing direction (left to right and vice verse) and its very annoying. it can also be done by defining special keys combination (such as alt + shift + 1) for each language but it's even more annoyingis there anything wrong with my definitions ?thanks alot[attachment deleted by admin - 90 dayss]
פורסם 2005 במרץ 1121 שנים ב-LANGUAGES תתקין את ...(INCLUDING THAI) זה הראשון שם. שים לב שזה RIGHT-TO-LEFT LANGUAGES. וב- ADVANCED שים אותו על HEBREW. מקווה שזה עזר.
