עזרה בבחירת מערכת למחשב
יש לי תקציב של 1000-1500 ש"ח, מה כדאי לי לקנות למשחב לשמיעת מוסיקה?
אני מתכוון, איזה כרטיס קול ואילו רמקולים?
ALtec Lansing FX6021 cost about 1400NIS in Pandas, this set should sound amazing even with Ob sound card.
If you presist to purchase new sound card plus speakers, the Audigy 2 is the best choise you can buy in in KSP for only 430 NIS, it comes in OEM which means just the card, you can get allmost the all programs from creative's site.
Speakers, you said that the main use is music, so the Altec Lansing VS4121 or Creative I-Trigue 3350 and the thired option should be also amazing is the Creative I-Trigue L-3500.
Altec Lansing VS4121 - 553NIS (Pandas), great choise.
http://www.pandas.co.il/product_info.php?cPath=1058_156&products_id=5550
Creative I-Trigue 3350 - 756NIS (Pandas), also good alternative.
http://www.pandas.co.il/product_info.php?cPath=1058_155&products_id=3109
Creative I-Trigue L3500 - 949NIS (Pandas), should be amazing.
http://www.pandas.co.il/product_info.php?cPath=1058_155&products_id=4562
Good luck with the purchase!  :)
