personal review on the creative zen touch
right]well first of all i have to say "sorry" that my review is in english, i just landed in the U.s and got my player and i promise that in the seconde ill get back ill write a review in hebrow, but for now if someone wants to translate it ill be happy.
so, first lets start of with the technical data.. this is the Creative Labs Zen Touch 20 GB MP3 Player and it holds about 10,000 songs... so first ill write the things i likedtehn the things i didnt, so, lets start:
good things:
the storge value is grate and campering bang for buck its about 80$ per gig, so thats very good, at leest for me. seconde things, it looks COOL!!!!!!!!! i would even dare to say it looks better then the ipod and the back blue light is slick, one of the tings one can like or hate is the "tocuh pad" if you used a laptop ever then its just the same, you just move you finger on the white line and thats how you pick the song or the options, for me, its grate!. the transfer rate is very fast and 200 songs were transferd in about 5 minute (but im not sure because i didnt actualy timed it) and the softwere that comes with it is very easy to use and "idiot-pruf" and the visuals is also slick and makes it look like an ipod rip-off. the headphones are grate and it comes with a lather case for it.
now to the things i didnt like:
forst of all, the battry life is crappy with only 24h... and for someone on the road like me its crappy... i didnt tried to buy a car plug but i guess it costs about 50$ moreand one of the things that realy almost made me give it back is that in the manual there is nothing about a riset button and when i froze up i tried to find it for about 15 minuts until i found it (just under the volume adjustment) and the besides that its grate
final score:
looks - 9
bang for buck - 8
display and iterface - 8
battery life - 6
accessories - 7
final score (my personal score) - 8.9
proce: 230$ on amazon.com
לול? הפיצ'ר הכי מושך ובולט של הנגן הזה היא הבטרייה שלו.
דווקא לה נתת ציון רע?
מוזר.
תגיד אחי, הוא נכנס בקלות לכיס?
הוא מספיק קומפקטי, לפחות לטעמך?
yep.. very compactic and slides in great.. the thing that makes it less compactic but more safe is the "travek bag" that is like the old covers for your cell-phone.. its protecting it but it makes it less reacheble.. but even with that i is very small...
and the battry life is 24 H on the box... i never got to se how long it lasts out side of it...
