? MP3 Flash PlayersLexar or MuVo
Both are 256MB, both have a litle LCD, which is better? I have now the lexar, but I can replace it with the muvo for quite the same cost. Is it worth the time? is it worth anyway? Or should I just keep the lexar?
Thanks, prexus
אם אתה נהנה מהלקסר
אז בשביל מה להחליף ?
