Choosing the right gaming monitor for 2025
Hello everyone,
I am looking to buy a new monitor for gaming and work. After researching, I found some important factors to consider:
Refresh rate: 144 Hz or 165 Hz or higher will help make the gaming experience smoother.
Resolution: 2K or 4K depending on your needs; 2K is a balanced choice between performance and image quality.
Response time: Should choose 1-5 ms to avoid ghosting.
Screen technology: IPS for vivid colors, TN for fast speed, and VA for high contrast.
Does anyone have experience with or use any monitors that they would like to suggest to me?
I would also love to hear reviews of gaming monitors in the 1500-2500 NIS price range.
Thanks in advance! Retro Bowl 26
נערך על-ידי willsmith
הצטרפ/י לדיון
אורח
הוסף תגובה
