שדרוג מחשב לגיימינג ,תקציב 2000 ש"ח
שלום ,
אני מעוניין לשדרג את המחשב הנוכחי שלי שיהיה גם לגיימינג (משחקים כמו fallout 4 ו-GTA V) ללא OC
החומרה שלי :
[TABLE=width: 495]
[TR]
[TD]Seagate
[/TD]
[TD][TABLE=align: right]
[TR]
[TD]3TB - Barracuda 7200.14 series - SATA3 6Gb/s - 7200rpm - 64MB Cache - NCQ support
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]Seasonic
[/TD]
[TR]
[TD]450W - 80 Gold certified - Active PFC - 120mm ball bearing fan - 8pin CPU connector - 2 x 6 2 pin PCIe connectors
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]Samsung
[/TD]
[TR]
[TD]120GB Samsung 840 EVO - 2.5 inch - SATA3 6GB - 7mm - 540/410 MB/s Retail
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]Kingston
[/TD]
[TR]
[TD]8GB DDR3 1600MHz CL10 - 1.5v - PC3-12800 - HyperX Fury Series (Can be ordered in Red, Blue, Black or White) - 8192MB - HX316C10F/8
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]NANOXIA
[/TD]
[TR]
[TD]Deep Silence 1 Dark Black NPS
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]Gigabyte
[/TD]
[TR]
[TD]Socket LGA1150 CPU (Haswell, Broadwell) support - Intel H87 chipset - Dual channel DDR3 up to 1600 MHz memory - Integrated Graphics with VGA, DVI-D, HDMI video outputs - 2 PCI Express x16 slots - 8-channel audio - Gigabit LAN - 6 SATA3 6Gb/s - Up to 6 USB3.0 - ATX
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]Arctic
[/TD]
[TR]
[TD]Arctic-Cooling Freezer 7 Pro Rev.2 - Supports Intel sockets LGA775,1156,1155,1150,1366, AMD sockets AM3,AM2 ,AM2,939 - Excellent cooling performance up to 130 Watts - Ultra quiet 92mm PWM fan - 6 heatpipes and 42 fins for efficient heat dissipation - 900-2500 RPM - 45 CFM - Dynamic Fluid bearing
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]Intel
[/TD]
[TR]
[TD]i5-4590 Quad core CPU - LGA1150 - 3.3 GHz - 6MB cache - 22nm - 84W TDP - Integrated HD Graphics 4600 at 1150MHz - Haswell Refresh - Tray
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]ADATA
[/TD]
[TR]
[TD]8GB DDR3 PC3-12800 - CL11 - DDR3-1600 - 1.5V - Premier Series
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
מה יהיה הכי מומלץ להחליף בתקציב של 2000 ש"ח.
תודה.
אני לא רואה כ. מסך אז כדאי לך שיהיה אחד:)
www.startpc.co.il - סטארט מחשבים
אודים | חיפה | תל-אביב | אשדוד | קריית מלאכי
כרטיס מסך: 1679 ₪ - * מבצע * - Gigabyte GTX970 4GB WindForce3 OC 1114Mhz 4G DDR5
מחיר סופי: 1679 ₪ למזומן
1712 ₪ לאשראי עד 10 תשלומים
אני משתמש בכרטיס מסך המובנה בלוח אם.
אני יודע שהכרטיס מסך הוא העיקר .הכרטיס שהצעת לי, לפי מה שאני רואה באתר דורש ספק של 550 ולי יש 450 . השאלה היא, בתקציב שלי האם לשדרג ספק וכרטיס מסך או רק כרטיס עם דרישות מתח נמוכות יותר או שיש הצעה אחרת?
תודה.
^ בבדיקה שהבאת משתמשים במעבד אקסטרים שלבדו צורך 130W, לכן זה לא רלוונטי למקרה כאן. פותח הדיון ביקש התייחסות למערכת שקיימת אצלו והיא תצרוך בסביבות ה 300W.
הספק הזה עם 450W בהחלט יספיק.
נערך על-ידי Syszone
