רב תכליתי ב4K, בניתי מפרט, אבל אשמח לעזרה+תיקונים
[TABLE=width: 973]
[TR=class: pcheader]
[TD=class: pctype][/TD]
[TD=class: pctype]סוג[/TD]
[TD=class: pcimg]תמונה[/TD]
[TD=class: pcitem]שם המוצר[/TD]
[TD=class: pcitem3]יצרן[/TD]
[TD=class: pcitem3, align: center]אתר[/TD]
[TD=class: pcitem3, align: center]זמינות[/TD]
[TD=class: pcitem3, align: center]איפוס[/TD]
[TD=class: pcqnt, colspan: 3, align: center]כמות[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 20, bgcolor: #F0F3F1]blue_left.png[/TD]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]מעבד אינטל :[/TD]
[TD=class: pcimgr]lrg23578.jpg[/TD]
[TD=class: pcitemr]מק"ט: #31300Intel Core i7 4790K 4.0Ghz 8MB L3 Cache s1150 - Tray[/TD]
[TD=class: pcitemr1, align: center]newinfo.png[/TD]
[TD=class: pcitemr1, align: center]newkspinfo.png[/TD]
[TD=class: pcitemr1, align: center]newavailable.png[/TD]
[TD=align: center]refresh.png[/TD]
[TD=class: pcpm1, align: center]minus-icon.png[/TD]
[TD=class: pcqntr, align: center]1[/TD]
[TD=class: pcpm2]plus-icon.png[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]מאוורר למעבד :[/TD]
[TD=class: pcimgr]lrg8530.jpg[/TD]
[TD=class: pcitemr]מק"ט: #18914Arctic Freezer 7 Pro Rev.2 CPU Cooler[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]לוחות אם למעבדי אינטל :[/TD]
[TD=class: pcimgr]lrg23023.jpg[/TD]
[TD=class: pcitemr]מק"ט: #30887Asus Z97-K LGA1150, Intel Z97, DDR3 1600, 2xPCI-E, VGA, DVI, HDMI[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]זכרונות :[/TD]
[TD=class: pcimgr]lrg22058.jpg[/TD]
[TD=class: pcitemr]מק"ט: #29895Transcend 1x8GB DDR3 1600Mhz CL11 JM1600KLH-8G[/TD]
[TD=class: pcitemr1, align: center]newunavailable.png[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]זכרון לניידים :[/TD]
[TD=class: pcimgr]lrg0.jpg[/TD]
[TD=class: pcitemr][/TD]
[TD=class: pcitemr1][/TD]
[TD=class: pcqntr, align: center]0[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]כרטיסי מסך :[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]דיסקים קשיחים :[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]כונני SSD :[/TD]
[TD=class: pcimgr]lrg26608.jpg[/TD]
[TD=class: pcitemr]מק"ט: #33514Crucial BX100 CT250BX100SSD1 250GB SSD SATA III[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]דיסקים קשיחים לניידים :[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]צורבי DVD :[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]כרטיסי קול :[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]ציוד רשתות :[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]ספקי כוח :[/TD]
[TD=class: pcimgr]lrg25974.jpg[/TD]
[TD=class: pcitemr]מק"ט: #33052Corsair 550W Active PFC 80+ VS550 PSU[/TD]
[/TR]
[TR=class: pcrow]
[TD=class: pctyper, width: 125, bgcolor: #F0F3F1]מארזים :[/TD]
[TD=class: pcimgr]lrg23668.jpg[/TD]
[TD=class: pcitemr]מק"ט: #31367Antec GX500 Window Black Steel Case No PSU[/TD]
[/TR]
[/TABLE]
טוב אז בניתי המפרט הנ"ל, אבל כבר זמן רב שאני לא בענייני החומרה, והעולם הזה מאוד מתעדכן, לכן אשמח לתיקונים הערות, "למה שמת את זה ולא את זה" (:
השימוש במחשב הוא לאינרנט, לעיתים פוטשופ ולעיתים תוכנות של עיצוב פנים, חשוב לי שהמחשב ירוץ מאוד מהר, ויוכל לשאת על גבו הרבה חלונות פתוחים.
זמן רב שאני לא משחק במחשב, אבל בכל אופן אני רוצה לקנות גם קונסולה, אז אין צורך להתאים את המפרט לכך.
אני לא מתכנן אובקלוקינג, אבל אופציה לשיפורים בעתיד אשמח, כמו הוספת זכרון וכו'..
1. מה התקציב המקסימאלי?
4K
א) האם לנצל את כל התקציב או לנסות ולחסוך?
לנצל
ב) במידת הצורך - עד כמה ניתן לחרוג מהתקציב?
500nis
עבודה משרדית ולעיתים עריכה גרפית
א) במידה והמחשב מיועד לתוכנות עיקריות ספציפיות, יש לרשום אותן ואופן שימוש (מזדמן/תדיר/כבד/פרנסה)
-מהי הרזולוציה הטבעית (מקסימאלית) של המסך שיחובר למחשב (ניתן לציין גם גודל מסך).
1920*1080 23'
-לאילו הגדרות גרפיות מיועד המחשב (נמוכות/בינוניות/גבוהות)?
3. האם יש צורך בציוד הקפי (לדוגמא: מקלדת, עכבר, רמקולים ועוד)? אם כן, ניתן לרשום גם העדפות לדגמים.
לא אין צורך
5. עד כמה חשוב השקט בסולם של 1 עד 8 (8 = יש לנסות ולהקפיד על השקט)?
4, רצוי שקט, אבל נסתדר בכל מקרה
6. האם מתוכנן אוברקלוק (OC)? אם כן איזה (קל, בינוני, כבד)?
לא מתוכנן
לא
לא משנה איזה חנות, אני מתגורר בעמק יזרעאל
9. מתי מתוכננת קניית המחשב?
בשבועיים הקרובים
10. האם יש בקשות מיוחדות כלשהן? (לדוגמא תמיכה בהתקנים/חיבורים כגון FW/RAID/USB3/ESATA, חיבורי האודיו מרובים/חיבור אופטי, דרישה לחומרה ספציפית וכדומה).
רצוי USB3
11. האם חשוב לשמור על אופק שדרוג המחשב? האם מתוכנן שדרוג מאסיבי של המחשב בעתיד?
רצוי לשמור על אופק שדרוג
מעדיף לוח אם של אסוס
תודה רבה מראש!!
---מקפיץ ושואל האם אני צריך כרטיס למסך, לעבודה מידי פעם עם פוטושופ, לא משהו אינטנסיבי---
נערך על-ידי Fox המקורי
up
מעבד שאין לך צורך בו, אתה יכול לחסוך 700 שקל ולקחת I5
לוח אם עם פיצ'רים מיותרים לצרכים שלך, ניתן לחסוך עוד כ 200 שקל
SSD הייתי לוקח SAMSUNG EVO
ספק כוח גם הוא מיותר לחלוטין לצרכים שלך, אלא אם כן אתה משאיר את זה לאופציה לשדרוג והוספת כרטיס מסך,
מה שכן, אתה יכול להוריד במעבד/לוח-אם ולהוסיף כרטיס מסך 7950 שעולה היום 770 שקל בערך
