חוות דעת על מפרט שבניתי
[TABLE=width: 100%]
[TR]
[TD][TABLE=width: 100%]
[TR]
[TD=align: right]פרטי המוצר
[/TD]
[TD=width: 36]step1.gif[/TD]
[/TR]
[/TABLE]
[TABLE=width: 100%]
[TR]
[TD=width: 70]סהכ מחיר[/TD]
[TD=width: 70]מחיר בשקלים כולל מעמ[/TD]
[TD=width: 70]כמות[/TD]
[TD]שם[/TD]
[/TR]
[TR]
[TD=align: right]₪ 1522[/TD]
[TD]1[/TD]
[TD]CM8064601560722.jpgIntel-CM8064601560113-i7-4790 Quad core CPU - LGA1150 - 3.6 GHz - 8MB cache - 22nm - 84W TDP - Integrated HD Graphics 4600 at 1200MHz - Haswell Refresh - Tray[/TD]
[/TR]
[TR]
[TD=align: right]₪ 452[/TD]
[TD]1[/TD]
[TD]Fatal1ty-B85-Killer.jpgASRock-Fatal1ty-B85-Killer-Fatal1ty B85 Killer - Socket LGA1150 CPU - Intel B85 chipset - DDR3 1600MHz memory support - VGA, DVI-D and HDMI video outputs - 7.1 CH HD Audio - TI NE5532 Premium Headset Amplifier - SPDIF - Atheros Killer E2200 Gigabit LAN - 2 x PCIe x16 slots - 4 x SATA3 6Gb/s - 2 x SATA2 3Gb/s - up to 4 USB3.0 ports - ATX[/TD]
[/TR]
[TR]
[TD=align: right]₪ 718[/TD]
[TD]1[/TD]
[TD]AM2U16BC8R2-B-Kit.jpgADATA-AM2U16BC8R2-B-Kit-16GB (2x8GB) kit DDR3 PC3-12800 - CL11 - DDR3-1600 - 1.5V - Premier Series[/TD]
[/TR]
[TR]
[TD=align: right]₪ 1773[/TD]
[TD]1[/TD]
[TD]426018336-3361.jpgGainward-426018336-3361-PC-GeForce GTX970 GPU - 4GB 256 bits GDDR5 memory - Mini HDMI, DVI-I , 3 x Mini DisplayPort video outputs - GPU/Memory clocks 1152/7000 MHz - Phantom Edition - With new PC Only - Comes with NVIDIA PickYourPath 2014 free game[/TD]
[/TR]
[TR]
[TD=align: right]₪ 582[/TD]
[TD]1[/TD]
[TD]CT128MX100SSD1.jpgCrucial-CT256MX100SSD1-256GB MX100 Series - SATA3 6Gbps 2.5 inch Internal SSD - 7mm - 550/330 MBps Read/Write[/TD]
[/TR]
[TR]
[TD=align: right]₪ 282[/TD]
[TD]1[/TD]
[TD]ST2000DM001.jpgSeagate-ST1000DM003-1TB - 3.5 inch - SATA3 6Gb/s - 7200rpm - 64MB Cache - Barracuda 7200.14 series[/TD]
[/TR]
[TR]
[TD=align: right]₪ 542[/TD]
[TD]1[/TD]
[TD]Z3-Plus.jpgZalman-Z3-Plus-600-Z3 Plus Midtower case with Window - 600W Zalman ZM600-LX[/TD]
[/TR]
[TR]
[TD=align: right]₪ 123[/TD]
[TD]1[/TD]
[TD]ZM-DF12.jpgZalman-ZM-DF12-120mm Case fan - Blue LED - Anti-Vibration Silicone Pins and Noiseless Connector included - Speed 1,000 - 1,800rpm - Noise Level 20.0dBA - 32.0dBA - Sleeve Bearing Type[/TD]
[/TR]
[TR]
[TD=align: right]₪ 82[/TD]
[TD]1[/TD]
[TD]GH24NS95.jpgLG-GH24NSB0-x24 DVD-RW Drive with M-DISC™ Support - Burns DVD+R/-R discs at 24x speed - SATA interface - Black (GH24NSC0)[/TD]
[/TR]
[TR]
[TD=align: right]₪ 1[/TD]
[TD]1[/TD]
[TD]SERVICEFORUM.jpgPlonter-SERVICEFORUM-הרכבת מחשב, חיווט ובדיקות מקיפות חינם להזמנה של חבר פורום. זיכרו למלא בעת פתיחת בכרטיס הלקוח מאיזה פורום הגעתם או הודיעו לנו אחרי[/TD]
[/TR]
[TR]
[TD=width: 150, align: right]
59556077[/TD]
[TD=colspan: 2, align: right]
:במזומן:באשראי[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
רציתי לדעת אם כמה דברים על המפרט:
1.האם אפשר להוריד את המאוורר שהוספתי
2.האם אפשר לשים לוח אם פחות יקר אבל עם ביצועים דומים (ואיזה)
3.האם הכרטיס מסך של gainward טוב או שממולץ להחליף ל MSI למרות שיש הבדלי מחירים
תודה מראש! :cognee:
