צריך דעה על מפרט שבניתי לגיימינג ועריכה
[TABLE=class: t1, width: 619]
[TR]
[TD=class: td1]מק"ט
[/TD]
[TD=class: td2]מוצרים
[/TD]
[TD=class: td3]כמות
[/TD]
[TD=class: td3]מחיר
[/TD]
[/TR]
[TR]
[TD=class: td1]N760OC2GD
[/TD]
[TD=class: td2]Gigabyte Geforce GTX760 Windforce X3 2GB RETAIL
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪1566
[/TD]
[/TR]
[TR]
[TD=class: td1]GZ87HD3
[/TD]
[TD=class: td2]Gigabyte GA-Z87-HD3 for 1150
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪647
[/TD]
[/TR]
[TR]
[TD=class: td1]C4770T
[/TD]
[TD=class: td2]Intel Core i7 4770 3.5Ghz (3.9Ghz Turbo) LGA1150 Tray
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪1492
[/TD]
[/TR]
[TR]
[TD=class: td1]D316G16C9CRBSN
[/TD]
[TD=class: td2]Crucial 16GB KIT (8G X2) Crucial Balistix Sport CL9- בקניית מחשב חדש בלבד
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪555
[/TD]
[/TR]
[TR]
[TD=class: td1]MZ-7TD120BW
[/TD]
[TD=class: td2]Samsung 120GB 2.5" SSD 840 Series
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪489
[/TD]
[/TR]
[TR]
[TD=class: td1]ST2000DM001
[/TD]
[TD=class: td2]Seagate Barracuda 7200.14 2TB SATA3
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪456
[/TD]
[/TR]
[TR]
[TD=class: td1]FD-R4-RA-650
[/TD]
[TD=class: td2]באנדל - Fractal Design Define R4 + FSP RAIDER 650W - בקניית מחשב חדש
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪745
[/TD]
[/TR]
[TR]
[TD=class: td1]SCMG3100
[/TD]
[TD=class: td2]Scythe MUGEN 3 REV B
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪209
[/TD]
[/TR]
[TR]
[TD=class: td1]WN7-00403
[/TD]
[TD=class: td2]Microsoft Windows 8 Home Premium ENGLISH 64 BIT
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪375
[/TD]
[/TR]
[TR]
[TD=class: td1]SST-FP37B
[/TD]
[TD=class: td2]SilverStone USB 3.0 Card Reader Supporting SDXC
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪188
[/TD]
[/TR]
[TR]
[TD=class: td1]GH22NS70
[/TD]
[TD=class: td2]LG DVD-RW x22 Dual Layer Sata Black
[/TD]
[TD=class: td3]1
[/TD]
[TD=class: td3]₪110
[/TD]
[/TR]
[TR]
[TD=class: td4, colspan: 2]סה"כ:
[/TD]
[TD=class: td3]11
[/TD]
[TD=class: td3]₪6832
[/TD]
[/TR]
[/TABLE]
מה אתם אומרים על זה ומאיפה אפשר להוריד או לשפר ?
חשוב לי לקבל תשובה כי אני צריך להזמין תודה.
לא ענית על השאלות בסטיקי וככה אי אפשר באמת לייעץ לך כמו שצריך.
מה שכן 1)אני דיי בטוח שאתה לא צריך I7. יספיק לך I5 שעולה 500 שקל פחות.
2)16GB זכרון זה מוגזם. 8 יספיק.
3) לא הייתי לוקח וינדוס 8, 7 לדעתי טוב יותר (ואם אתה יכול לקחת מחבר צרוב זה יחסוך לך).
4) קורא כרטיסים ב188 שקל? מיותר לחלוטין תקנה כזה נייד ב2 דולר באיביי.
נערך על-ידי ABL
4) קורא כרטיסים ב188 שקל? מיותר לחלוטין תקנה כזה נייד ב50 ש"ח.
זה נועד לעריכות כבדות ולפרנסה ופנאי ככה חשבתי ש i7 מוצדק כאן לרינדורים וכו'
ואיפה אמרת את זה?
תענה על השאלות שבסטיקי אחרת אי אפשר לעזור לך.
1. מה התקציב המקסימאלי? 6000
א) האם לנצל את כל התקציב או לנסות ולחסוך? לנסות לחסוך
ב) במידת הצורך- עד כמה ניתן לחרוג מהתקציב?200
2. מה שימושי המחשב (לדוגמא: משחקים, עריכה גרפית, עבודה משרדית, תכני HD וכדומה)? עריכות וידיאו AVID AFTER כבדות ומשחקים כבדים.
א) במידה והמחשב מיועד לתוכנות עיקריות ספציפיות, יש לרשום אותן ואופן שימוש (מזדמן/תדיר/כבד/פרנסה). גם לבית ולפרנסה AVID
ב) במידה והמחשב מיועד לגיימינג, יש לציין: BF3-4 וקרייסיס 3
-מהי הרזולוציה הטבעית (מקסימאלית) של המסך שיחובר למחשב (ניתן לציין גם גודל מסך). 1080P
-לאילו הגדרות גרפיות מיועד המחשב (נמוכות/בינוניות/גבוהות)?גבוהות
3. האם יש צורך בציוד הקפי (לדוגמא: מקלדת, עכבר, רמקולים ועוד)? אם כן, ניתן לרשום גם העדפות לדגמים. לא
5. עד כמה חשוב השקט בסולם של 1 עד 10 (10=שקט קרטי)? 7
6. האם מתוכנן אוברקלוק (OC)? אם כן איזה (קל, בינוני, כבד)? לא
7. האם האם יש צורך לכלול מערכת הפעלה/אופיס (אם כן רצוי לציין גרסה מועדפת) ו/או הרכבת מחשב בחנות? וונדוס 8
8. האם ישנה העדפה לרכוש את המחשב מחנות ספציפית? אם לא אפשר גם לציין איזור מגורים. TMS
9. האם יש בקשות מיוחדות כלשהן? (לדוגמא תמיכה בהתקנים/חיבורים כגון FW/RAID/USB3/ESATA, דרישה לחומרה ספציפית וכדומה). SSD וכרטיס מסך נוידיה ומעבדי האסוול
10. האם חשוב לשמור על אופק שדרוג המחשב? האם מתוכנן שדרוג מאסיבי של המחשב בעתיד? שיתמוך עד 32 ג'יגה זיכרון
הייתי הולך על משהו כזה:
מעבד:
Intel Core i7 4770 3.5Ghz (3.9Ghz Turbo) LGA1150 BOX
כמות: 1 - מחיר: ₪1526
לוח אם:
Gigabyte GA-B85-HD3 for 1150
כמות: 1 - מחיר: ₪484
מארז:
כמות: 1 - מחיר: ₪745
זיכרון:
כמות: 1 - מחיר: ₪555
קשיח למחשב שולחני:
Samsung 250GB 2.5" SSD 840 Series - בקניית מחשב חדש
כמות: 1 - מחיר: ₪770
קשיח למחשב שולחני:
כמות: 1 - מחיר: ₪456
כרטיס מסך:
כמות: 1 - מחיר: ₪1566
כונן אופטי:
כמות: 1 - מחיר: ₪110
הרכבה:
הרכבת מערכת מחשב כולל בדיקות מלאות וחיווט ברמה גבוהה לחברי הפורומים חינם או בהזמנה מעל 3500 ש"ח
כמות: 1 - מחיר: ₪0
סה"כ: ₪6212
מתחרים בכל הצעה בפורומים!
מחיר אחרי הנחת מזומן הינו: 6088 ₪
http://www.tms.co.il/preview/spec/xsr16kwe
http://www.tms.co.il/product/12255
או שקונה את הכרטיס מסך קצת יותר בזול מפה:
http://www.iqpc.co.il/Home/showItemMenu.asp?id=10049
תוך שבוע שבועיים המחירים צריכים לרדת.
הלוח ששמת במפרט סתם יקר ומיועד ל-OC שכן המעבד שלך לא מתאים וגם כמו בדרישה שלך שלא יבוצע OC
בנוסף לא צריך גם את הקירור שבחרת כיוון שלא יבוצע OC .
נערך על-ידי idanmal
אבל הלוח מתאים ל32 ג'יגה?
[TABLE=class: tblborder, width: 900, align: center]
[TR]
[TD=class: midborderline, align: left]Memory
[/TD]
[TD]
  1. 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
    * Due to a Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than the size of the physical memory installed.
  2. Dual channel memory architecture
  3. Support for DDR3 1600/1333 MHz memory modules
  4. Support for non-ECC memory modules
  5. Support for Extreme Memory Profile (XMP) memory modules
[/TD]
[/TR]
[/TABLE]
נערך על-ידי idanmal
נראה לי אלך על זה, ווינדוס חשוב לי וקירור עדיין בדילמה, פשוט היה לי מחשב עם קירור פשוט של אינטל והוא סבל מהתחממויות לאומת מחשב אחר עם קירור רציני ולא היו בעיות בכלל
[TABLE=width: 100%]
[TR]
[TD=width: 10%]מק"ט[/TD]
[TD=width: 45%]מוצרים[/TD]
[TD=width: 10%, align: center]כמות[/TD]
[TD=width: 10%, align: center]מחיר[/TD]
[/TR]
[TR]
[TD=width: 10%]GB85HD3[/TD]
[TD=width: 45%]Gigabyte GA-B85-HD3 for 1150[/TD]
[TD=width: 10%, align: center]1[/TD]
[TD=width: 10%, align: center]₪484[/TD]
[/TR]
[TR]
[TD=width: 10%]C4770T[/TD]
[TD=width: 45%]Intel Core i7 4770 3.5Ghz (3.9Ghz Turbo) LGA1150 Tray[/TD]
[TD=width: 10%, align: center]₪1492[/TD]
[/TR]
[TR]
[TD=width: 10%]D316G16C9CRBSN[/TD]
[TD=width: 45%]Crucial 16GB KIT (8G X2) Crucial Balistix Sport CL9- בקניית מחשב חדש בלבד[/TD]
[TD=width: 10%, align: center]₪555[/TD]
[/TR]
[TR]
[TD=width: 10%]N760OC2GD[/TD]
[TD=width: 45%]Gigabyte Geforce GTX760 Windforce X3 2GB RETAIL[/TD]
[TD=width: 10%, align: center]₪1566[/TD]
[/TR]
[TR]
[TD=width: 10%]MZ-7TD120BW[/TD]
[TD=width: 45%]Samsung 120GB 2.5" SSD 840 Series[/TD]
[TD=width: 10%, align: center]₪489[/TD]
[/TR]
[TR]
[TD=width: 10%]ST2000DM001[/TD]
[TD=width: 45%]Seagate Barracuda 7200.14 2TB SATA3[/TD]
[TD=width: 10%, align: center]₪456[/TD]
[/TR]
[TR]
[TD=width: 10%]FD-R4-RA-650[/TD]
[TD=width: 45%]באנדל - Fractal Design Define R4 + FSP RAIDER 650W - בקניית מחשב חדש[/TD]
[TD=width: 10%, align: center]₪745[/TD]
[/TR]
[TR]
[TD=width: 10%]GH22NS70[/TD]
[TD=width: 45%]LG DVD-RW x22 Dual Layer Sata Black[/TD]
[TD=width: 10%, align: center]₪110[/TD]
[/TR]
[TR]
[TD=width: 10%]WN7-00403[/TD]
[TD=width: 45%]Microsoft Windows 8 Home Premium ENGLISH 64 BIT[/TD]
[TD=width: 10%, align: center]₪375[/TD]
[/TR]
[TR]
[TD=width: 10%]SCMG3100[/TD]
[TD=width: 45%]Scythe MUGEN 3 REV B[/TD]
[TD=width: 10%, align: center]₪209[/TD]
[/TR]
[TR]
[TD=colspan: 2, align: left]סה"כ:[/TD]
[TD=align: center]10[/TD]
[TD=align: center]₪6481[/TD]
[/TR]
[/TABLE]
אחלה מקווה שעזרתי...
אומר רק שהקירור הזה מתאים יותר לביצוע OC ותוכל לחסוך אותו, אחלה מפרט אני הייתי הולך יותר לכיוון SSD בנפח של 250 גיגה.
הייתי מתפשר על הקירור ועל טרה של הרדיסק ובכסף הזה לוקח את ה-SSD של ה250 שבמעמד הקניה עולה 770 ש"ח, אני מאמין
שאם זה לעבודה ולמשחקים תצטרך להתקין עליו המון תוכנות ו120 נגמר מהר מנסיון.
