פורסם 2013 במרץ 1713 שנים יש לי מחשב נובו, דגם T5750 והזיכרון הפנימי 1GB ומעבד 2 GHz ושאלתי היא : מה זה REJUVENATE MY SYSTEM האם זה במקום פירמוט (מדובר במחשב נייד לנובו שיש בתוכו תוכנת עזר להגנת המחשב) ? תודה לעונים לשאלתי... צבי.
פורסם 2013 במרץ 1813 שנים Description of Rejuvenation copied from the Rescue & Recovery Help window: Rejuvenating your systemWhen you select to rejuvenate your system, the Rescue and Recovery program optimizes system performance by completing the following actions:Performs a new incremental backup of your system. This backs up all new or changed files so that all current files are saved in a backup.Defragments your hard drive and backup files. This maximizes the performance of your hard drive and backups so that all your data is stored in the same place on your hard disk. This enables your data to be located and displayed more quickly.Restores your operating system and application files from a backup of your choice. This enables you to choose which backup to use to restore your computer. You might want to choose a particular backup that you know to be free of viruses, adware or spyware. Or, if you are having serious problems with your operating system or applications, you might choose to restore files that you backed up before you started having problems.Restores you current settings and some personal data from the registry. This enables your computer to retain the features that you had previously set up.The rejuvenation process maintains your current settings and data while helping to eliminate viruses, adware and spyware. Applications installed or uninstalled after the selected backup was created might need to be installed again to function correctly. This operation might take some time.
