LG NEXUS 4 הוכרז
  • תגובות 975
  • צפיות 123.8k
מיקרו סים זה ההוא שהוא בדיוק כמו סים רגיל רק קצת פחות "פלסטיק" נכון? לא כמו הנאנו שהוא "חדש לגמרי"...?
כן
מפרט מאוד מפורט של המכשיר:
External Hardware Specifications
Exact model: LG Nexus 4
Model Number{/B]: LG-E960
Dimensions: 133.9 x 68.7 x 9.1 mm (5.27 x 2.70 x 0.36 in)
Weight: 139 g (4.90 oz)
Construction: Corning Gorilla Glass 2 front & back, plastic bezel
Ports: 3.5mm headphone jack (top), microUSB (MHL) (bottom), microSIM tray (side)
Microphone: Dual Mics for Noise Cancellation
CPU
Exact model: Snapdragon S4 Pro APQ8064
Manufacturer: Qualcomm
Cores: Quad core "Krait v2"
Speed: 1.5GHz
Lithography: 28nm
Cache: L0: 4KB+4KB, L1: 16KB+16KB, L2: 2 MB
Instruction Set: ARMv7
Pipeline Depth: 11-Stage
Dhrystone: 3.3 DMIPS/MHz
Memory: Dual-channel 533 MHz (8.5 GB/sec)
Integrated Radios: BT 4.0, 802.11ac/a/b/g/n (2.4/5 GHz)
GPU
Exact model: Adreno 320
OpenGL: ES 3.0
Baseband
Exact model: Unknown
Bands: GSM/EDGE/GPRS (850, 900, 1800, 1900 MHz), 3G (850, 900, 1700, 1900, 2100 MHz), HSPA+ 42
DSP
Exact model: Hexagon QDSP6
Generation: H4
Clock Speed: 256MHz - 350MHz
Frequency: 500Mhz
Cache: L1: 16KB, L2: 256 KB
Lithography: 28nm
Dhrystone: 20 DMIPS/mW
Rear Camera
Exact model: Unknown - Sony BSI
Manufacturer: Sony
Max. Image Size: 3264 x 2448
Max. Video Size: 1080p 30fps
Sensor: 1/3.2" Back-Side Illuminated
Lens: LG 5 Element lens
Aperture: f/2.4
Flash: Single LED
Pixel Size: 1.1mµ
Screen
Exact model: Unknown - TrueHD IPS+
Manufacturer: LG
Display Type: IPS
Resolution: 1280x768
Aspect Ratio: 15:9
Pixel Density: ~318ppi
Brightness: 470 nits
Sub-pixel Arrangement: Stripe TGM RGB
Black Screen (100% Brightness): 0.33 cd/m2
White Screen (100% Brightness): 471 cd/m2
GPS
Exact model: gpsOneGen 8A
GLONASS: Supported
A-GPS: Supported
RAM
Technology: LPDDR
NAND
Size: 8GB or 16GB
Battery
Exact model: LG BL-T5
Manufacturer: LG Chem
Capacity: 2100mAh/8.0Wh (minimum 2030mAh/7.7Wh)
Voltage: 3.8v
Type: Lithium-ion polymer
אני עדיין עם הגוגל נקסוס 1, נראה לי שזה יהיה הטלפון הבא שלי.
יש לו Dual Sim?!
לא חשוב - חשבתי שראיתי תחת פורטים שיש שתי "כניסות" Micro SIM, עכשיו מהסתכלות חוזרת - ראיתי שאחד מהם זה Micro USB...
איפה ראית כזה דבר?
איפה? במוחי. למה? כי אני דביל.
חבל שהוא טיפה יותר כבד, דווקא ציפיתי לעוד הרזיה קטנה.
במחיר כזה אין בכלל התלבטות, אפילו שיש לי galaxy nexus... בהזדמנות הראשונה.
עוד אין מבחני השוואה
לאופטיקאים שבחבורה... אם הנתונים ש-freesoul23 מדוייקים - איך הטלפון הזה מתמודד עם galaxy s3 בזירת הצילום?
אני נוסע אוטוטו לקנדה, שוקל להזמין אחד מהשניים
ב-13 בנובמבר מתחילה המכירה, או שכבר אפשר לקנות את המכשיר? יש לי חבר בארה"ב שחוזר בלילה שבין 13 ל-14 יש אפשרות שהוא יוכל לקנות את זה או שהוא מפספס בכמה ימים?
הרשה לי לצטט לך מהחדשה שפורסמה כאן אצלנו באתר, Nexus 4 שובר את כל המוסכמות:
המכשיר יהיה זמין דרך ה-Play Store של גוגל ב-13/11 בארה"ב, קנדה, בריטניה, גרמניה, צרפת, ספרד ואוסטרליה; ויצא לחנויות עד סוף נובמבר באירופה, במדינות אמריקה הדרומית והמרכזית, באסיה, במזה"ת ובמדינות הסובייטיות (לשעבר). מחיר המכשיר הוא ככל הנראה הדובדבן שבקצפת הנקסוס המתקתקה: 299$ בלבד לגרסת ה-8GB, ו-349$ לגרסת ה-16GB.
קראתי את זה. השאלה שלי, האם יש אפשרות למשלוח מהיר באותו יום או משהו דומה, או שמשלוח לוקח כמה ימים?
קיים בארה"ב המושג "משלוח 24 שעות", אבל אני בספק שתצליחו.
כמובן שתהיה התנפלות על המכשיר בהתחלה, אין לדעת מתי המכירה תתחיל, ומתי זה יגיע.
שני חברים שלי ניסו להזמין את הגוגל נקסוס מPLAY... תהליך מתיש למי שלא אמריקאי.
