C#-WCF-TransactionScope-RollBack
העלתי את הבעיה שלי ל http://stackoverflow.com/questions/10270729/wcf-transactionscope-doesnt-rollback#
עזרתם לי הרבה בפעמים הקודמות אז למה לא להמשיך לאתגר אותכם.
וחשבתי שאולי תוכלו לתת לי עצה או פתרון במקביל וגם למה לא אם הוא בעברית !
I have a service and client Application and I dont have a clue what is the problem with this code. after doing this line perfectly and save it in my DB,
proxy.AddEmployee("Stav", "20");
the next line throw Exception becouse I didnt send a number to the Age parameter, but the Transaction doesnt RollBack the first line so the Information : Stav, 20 still exsist in my DB!
proxy.AddEmployee("Stav123", "Not a Number(-->will do Exception)")
client:
static void Main(string[] args)
ServiceReference1.IJob proxy = new ServiceReference1.JobClient();
using (TransactionScope ts = new TransactionScope(TransactionScopeOption.Required))
try
proxy.AddEmployee("Stav123", "Not a Number(-->will do Exception) ");//stop the running and show the Exception but keep the stav,20 in DB
ts.Complete();
catch
ts.Dispose();
service:
[ServiceContract]
public interface IJob
[OperationContract]
[TransactionFlow(TransactionFlowOption.Allowed)]
void AddEmployee(string Name, string Age);
public class JobImplement:IJob
[OperationBehavior(TransactionScopeRequired = true)]
public void AddEmployee(string Name, string Age)
string strConnection = @"Data Source=.\SQLEXPRESS;AttachDbFilename=C:\Users\stavalfi\Desktop\WCF2\ConsoleApplication4\WCF_DB.mdf;Integrated Security=True;Connect Timeout=30;User Instance=True";
SqlConnection objConnection = new SqlConnection(strConnection);
objConnection.Open();
SqlCommand objCommand = new SqlCommand("INSERT INTO Employee (Name,Age) " + "VALUES ('" + Name + "' ,'" + Age + "')", objConnection);
objCommand.ExecuteNonQuery();
objConnection.Close();
WSHttpBinding Basic = new WSHttpBinding();
Basic.TransactionFlow = true;
ServiceHost host = new ServiceHost(typeof(JobImplement), new Uri("[url]http://localhost:8080"[/url]));
ServiceMetadataBehavior behavior = new ServiceMetadataBehavior();
behavior.HttpGetEnabled = true;
host.Description.Behaviors.Add(behavior);
host.AddServiceEndpoint(typeof(IJob), new BasicHttpBinding(), "Request123");
host.Open();
Console.WriteLine("opened");
Console.ReadLine();
host.Close();
עריכה : נפתר
הגדרתי את החיבור למעלה שאני רוצה להשתמש בו ולא השתמשתי בו.. טעות מפגרת חח
