Where can I fix my In Ear Monitors in the merkaz area?
Ive got the ultimate ears tf 10, but recently the casing of one of the earphones broke and 2 cables inside ripped.
I just need to find a lab that can weld those 2 small cables together again.
Please tell me if you know of one.
Thanks!
נסה את אדר סוכנויות אודיו ברח' החשמונאים בת"א.
http://www.d.co.il/4639920/36860/
I was there and they said they dont work on IEMs
Maybe you know of a similar shop that I can try?
ty
Another shop in Givatayim, Fuse Stereo:
http://fuse.co.il/
Not sure if they have a lab or whether they do any repairs but it's worth a try.
Good luck.
