ביקורת על מפרט מחשב+מסך למשחקים בתקציב מוגבל של עד 3600 ש"ח
MidiTower ATX Model HEC CI-6C28 / Huntkey V403---מארז
Silent rear fan 12cm. In front 2 x USB, audio. Black or Silver-Black
Chassis Dimensions (WxHxD) 190 x 410 x 450 mm
Huntkey V-Power - power supply 550W---ספק כוח
14cm silent fans, 6-pin for power graphics card connector
Intel® Core™ i3-2100, LGA1155 Package 3.1GHz--מעבד
Dual Core with Hyper-Threading 2/4 Engine, 32nm, 65W, 3MB Cache L3
Intel Extended Memory 64 Technology, Intel Virtualization Technology VT-x
Enhanced Intel SpeedStep®.
Integrated Dual Channels of DDR3 1333MHz memory controller
Integrated Intel® Graphics Media Accelerator HD2000 850MHz (max 1.1GHz)
Intel Buffalo Flat DP67BA----לוח אם
Intel P67 Express Chipset, 1066/1333-MHz FSB, ATX
LGA1155 CPU Socket, Intel® Core™ i3, i5, i7 processor ready
4*DIMM 240-pin Dual Channel DDR3 1066/1333/1600MHz Up 32GB
1*PCI Express x16 v2.0, 2*PCI Express x1, 3*PCI,
6(+8)*USB2.0 & 2*USB3.0, 1(+1)*IEEE1394
P67 PCH 4*SATA-2 & 2*SATA-3 controller, Matrix SATA RAID (0,1,10,5)
Integrated: Realtek ALC892 High Definition Audio 7.1+2 codec, Optical out
Intel PRO® 82579V 10/100/1000Mbps RJ45 Ethernet controller
Kingston 4GB Dual Channel DDR-3 1333MHz (2x2GB--זיכרון
Gainward Geforce GTX-550Ti--כרטיס מסך
PCI Express x16, 1024MB DDR5 192-bit. up to 170W
GPU/Memory clockspeed 900/2050MHz, 2 slot, 1 fans cooler
VGA, DVI & HDMI. DirectX v11 compatible
LG GH22NS70 DVDRW SATA, SecurDisk™
Write Sp: DVD±R: 22X, DVD+RW: 8X, DVD-RW: 6X, DL ±R: 10X, DVD-RAM: 12X, CD-R/RW:48X32
WD Caviar Blue WD5000AAKS 500Gb 7200rm SATA-3 16Mb Cache--הארד דיסק
Set Silver Line // Genius // Gigabyte USB Black--מקלדת+עכבר
Multimedia Keyboard Eng-Heb(-Rus) & Optical Wheel mouse. Black
Philips 229CL2SB 21.5" Super Slim LED 16:9 Black22"[/b---מסך "22"
0.248pp TFT TN panel. Brightness 250,
Contrast Ratio 1000:1, Dynamic Contrast Ratio 20.000.000:1
Viewing H/V 170/160, 1920x1080. Video Response time 2ms
Analog/Digital DVI-D
סה"כ מחיר: 3550 ש"ח
אשמח לשמוע הצעות או הערות על המפרט,
כמובן שהתקציב מוגבל ל3600 ש"ח
תודה רבה,
לירן
  • תגובות 34
  • צפיות 3k
המפרט הנ"ל די גרוע. המסך הוא TN פשוט, המקלדת עכבר - פשוטים, הוא לא חזק במיוחד לגיימינג. הספק של חברת אף אחד ובניו.
בתקציב כזה אפשר לקבל:
I3 2100 + לוח Z68 + לפחות 4GB זיכרון + כ.מסך חזק יותר כמו GTX460 / HD6850 + מארז עדיף + ספק 450W איכותי + מסך גדול ואיכותי יותר. וכל זה בלי להתאמץ אפילו למצוא מקום זול.
ספק כוח ג'נרי
לוח אם מבוסס P67, מיותר למעבד שלך
כרטיס מסך חלש יחסית לתקציב וגם לרוב לא משתלם בלי שום קשר למפרט
מסך מבוסס פאנל TN, בתקציב שלך אפשר יותר טוב
מלא את השאלון בסטיקי, כך יהיה יותר קל לעזור לך
כרטיס מסך קצת חלש + מארז וספק ג'נריים בהחלט לא יספקו את הסחורה, בנוסף למטרות גיימינג יש להשקיע בציוד היקפי איכותי, בגלל שלא כללת אוזניות/רמקולים הנחתי שאינך זקוק להן ולכן רק כללתי מקלדת ועכבר איכותיים:
מעבד:
Intel 2100 3.1GHz 1155 3MB with graphics tray
כמות: 1 - מחיר: ₪479
קירור למעבד:
Scythe KATANA 3 1156 / 1366 only
כמות: 1 - מחיר: ₪114
לוח אם:
Gigabyte GA-Z68A-D3-B3
כמות: 1 - מחיר: ₪550
מארז:
Lancool Midi Tower PC-K7B Black + FSP 700W Bronze 80 - בקניית מחשב חדש
כמות: 1 - מחיר: ₪682
קירור למארז:
Raidmax 120mm Retail Quiet Fan
כמות: 1 - מחיר: ₪22
זיכרון:
Kingston 4GB DDR3 1333 - מחיר חם
כמות: 2 - מחיר: ₪104
כרטיס מסך:
SAPPHIRE HD 6850 1GB - בקניית מחשב חדש מעל 2500 ש"ח
כמות: 1 - מחיר: ₪630
כונן אופטי:
LG DVD-RW x22 Dual Layer Sata Black
כמות: 1 - מחיר: ₪100
מקלדת:
Wired Keyboard 600 Microsoft
כמות: 1 - מחיר: ₪59
עכבר פרו-גיימינג:
LOGITECH MX518
כמות: 1 - מחיר: ₪166
מסך:
Samsung Cream 2333T 23" Wide 8ms 1:50000 1920x1080 - מחיר סוף - מחיר בקניית מחשב חדש מעל 2500 ש"ח מגיע ללא כבל DVI
כמות: 1 - מחיר: ₪685
סה"כ: ₪3695
מתחרים בכל הצעה ומפרט בפורומים!
מחיר אחרי הנחת מזומן הינו: 3622 ₪
http://tms.co.il/preview/spec/fa94dpvl
דוגמא למפרט טוב, כולל מארז שאני אישית מאוד מאוד אוהב וספק במחיר מציאה (קצת מוזר לדעתי). ניתן לקחת מארז + ספק זולים יותר ולשדרג במעט את כרטיס המסך, בכל אופן לא יתן הבדל ביצועים משמעותי ובעתיד אני בטוח שתשדרג את כרטיס המסך בעת הצורך.
נ.ב הקירור הנוסף למארז הוא טעות שלי.
^ זה בדיוק מה שצריך לעשות. לרדת במארז וספק ולקחת 6870 במקום. אולי גם לקחת לוח H67. ועוד איך יהיה הבדל ביצועים.
אני מסכים, Z68 די מבוזבז פה, אפשר לנצל את התקציב יותר בצורה שתניב יותר ביצועי גיימינג:
₪114
Intel BLKDH67CL Cold Lake + 8GB DDR3 1333Mhz, יחידות 1
₪668
http://www.rsm.co.il/product.aspx?productid=3091
Samsung 1TB=1000GB 7200RPM 32MB Sata F3 HD103SJ , יחידות 1
₪277
http://www.rsm.co.il/product.aspx?productid=1257
Intel Sandy Bridge Core i3 2100 Socket 1155 3MB 3.1Ghz Tray, יחידות 1
₪505
http://www.rsm.co.il/product.aspx?productid=2522
מאוור Cooler Master Hyper TX 3 , יחידות 1
₪99
http://www.rsm.co.il/product.aspx?productid=1195
NZXT Source 210 + Cougar RS400 32A @ 12V, יחידות 1
₪389
http://www.rsm.co.il/product.aspx?productid=3156
HIS 6870 IceQ X 1GB GDDR5 ברכישת מחשב חדש, יחידות 1
₪799
http://www.rsm.co.il/product.aspx?productid=3097
מסך Samsung Cream 2333T 23" Wide 8ms PVA 1:50000 1920x1080 ברכישת מחשב חדש מעל 2500 ש"ח, יחידות 1
₪699
http://www.rsm.co.il/product.aspx?productid=2966
מקלדת חוטית Microsoft Wired Keyboard 200 USB, יחידות 1
₪49
http://www.rsm.co.il/product.aspx?productid=1290
GigaByte GM-M6580 Laser, יחידות 1
₪56
http://www.rsm.co.il/product.aspx?productid=2225
הרכבת מחשב מעל 3000 ש"ח ובדיקת מאמץ לחלקים, יחידות 1
₪50
סה"כ מחיר לכל המוצרים:₪3705
₪114
₪668
₪277
₪505
₪99
₪389
₪799
₪699
₪49
₪56
₪50
המפרט נראה אחלה ,
8G זיכרון של איזה חברה?
אפשר לקחת מקלדת -Microsoft Digital Media Keyboard 3000 - יותר טובה?למרות שזה עוד 50 ש"ח
האמת שאני לא מכיר את האתר/חנות המחשבים הזאת(אני מב"ש)
מקום אמין? אחריות? שרות?
המומחה מה אתה אומר??
תודה רבה על העזרה :) אשמח לתגובות נוספות
לירן
אני חושב שכל זה פשוט סתם בזבוז באותו תקציב אפשר כבר לקחת את המפרט הבא שעדיף בהחלט :xyxthumbs:
http://tms.co.il/preview/spec/k6p7d9j5
מפרט חזק במיוחד לגיימינג כבד, שקט רמת רעש בערך 6 אולי קצת יותר.
שים לב למאוורר הג'נרי שכללת, לוח אם הפשוט ביותר שלא כולל שום פיצ'ר אלמנטרי, מסך TN נחות, לא כללת מקלדת ועכבר.
אתה עדיין חושב שזה בזבוז?
בהתחשב בזה שהמפרט מעלי כולל רק מאוורר אחד אפשר גם להיפתר מימנו מה שמוריד לנו עוד 15 שקל, על איזה פיצ'ר אלמנטרי אתה מדבר ? SATA3 אין ניצול כרגע USB3 גם כן אין ניצול כרגע בקטע של לא שווה וממש לא שווה לבזבז על זה כסף, מסך TN מעולה במחיר ממש טוב וה2333T ממש לא מסך טוב יש לו באג דפוק של צל במשחקים שזה דיי מעצבן הייתי אומר וגם מישהו כאן תמיד אמר שאין הבדל במשחקים בין TN\PVA\IPS ככה שזה לא משנה, לגבי העכבר והמקלדת שים לב מה כתוב שהם.
ועוד איך אני חושב שזה מפרט שווה יותר, I3 2100 + HD6870 נגד I5 2400 + GTX560TI, לא יודע זה בטח שאלה קשה אבל אני בוחר את האפשרות השנייה :cool2:
עוד אפשרות ירידה בכרטיס מסך לHD6870, ב3500 שקל בדיוק.
http://tms.co.il/preview/spec/wumagk6q
מפרט חזק במיוחד לגיימינג כבד, שקט רמת רעש בערך 7.
"שקט רמת רעש" לא קיים בשפה העברית.
אם המחשב למשחקים נטו אז אין הבדל בין המעבדים. אחרת, לשימושי טקסטים - אינטרנט, מעבד תמלילים, עדיף פאנל IPS\PVA.
עדיין אותו לוח שלא הייתי לוקח בהיעדר תקציב לחוץ (אין צורך ממשי ב-I5)
אז מה אתם אומרים ללכת על ההצעה של המומחה??
תעזרו לי להחליט :(
תודה,
לירן
בהתבסס על האין צורך בI5 קבל מפרט מי TMS :xyxthumbs:
http://tms.co.il/preview/spec/mjy2nzv9
אותו מפרט בדיוק כמו המפרט מי RSM רק זול יותר.
יש את אתר KSP - http://ksp.co.il/hmain.php?now_snif=beersheva
מישהו יכול לבנות לי משם מפרט למחשב כמו פה?? בניתי משהו קצת יותר יקר...
צירפתי את הקובץ: אשמח אם יהיו תגובות..
יש דגמים שונים אשמח אם מישהו יתאים לי משהו שיהיה הכי דומה להצעה האחרונה או להצעה של המשתמש המומחה,
תודה רבה על העזרה
לירן
[attachment deleted by admin]
