IPS חדש מבית ASUS נראה לא רע בכלל.
ASUS ProArt Series PA238Q Monitor Presents Total Color Fidelity
Created to meet the needs of graphic designers and other professionals, the IPS-paneled ASUS PA238Q joins the ProArt Series of displays as a 23”, LED-backlit model with native 1920 x 1080 resolution. It reproduces 100% of the sRGB color space, with every individual monitor precision calibrated at the factory to ensure unmatched color accuracy. The PA238Q ships with ASUS-exclusive QuickFit Virtual Scale software to display photos and documents in their true size on screen. In terms of ergonomics, a fully adjustable and sturdy stand complements a wide I/O range, which includes HDMI, DisplayPort, DVI-D, D-sub, and multiple USB ports.
Meticulous factory calibration
Guaranteeing authentic color performance, the PA238Q’s IPS panel is capable of delivering 100% of the sRGB color space, a feature pivotal in professional graphics work. IPS technology allows for 178° viewing angles, preventing color loss and wash even from extreme vertical and horizontal viewing directions. Precision individual calibration at the factory guarantees an average delta E factor lower than 5 for improved color fidelity. The internal firmware of the PA238Q uses a 10-bit lookup table for RGB coloration, going beyond the standard 8-bit table used in conventional monitors. This results in smoother and more accurate color gradation and reproduction. The contrast ratio comes in an incredible 50,000,000:1, generating true dark/light distinction and spectacular image quality. Combined with a 16:9 screen ratio, these features make the PA238Q a very capable monitor for entertainment applications such as movie viewing and gaming.
Productivity-boosting features
ASUS bundles exclusive QuickFit Virtual Scale functionality with the PA238Q, powering true-sized displays of photos and documents on the screen. Format sizes supported by the software include A4, letter, 8” x 10”, 5” x 7”, 4” x 6”, 3” x 5”, and 2” x 2”. It also supports alignment, centimeter and inch-based grids for added flexibility. Users can activate QuickFit via a simple hotkey at any time. This goes along picture-in-picture and picture-by-picture viewing for easier multitasking. Additionally, the PA238Q’s stand integrates fully-adjustable height, tilt, swivel, and pivot, making for easier work and enjoyment. The four conveniently-located USB ports on the PA238Q (two on the side, two on the back) afford easy access to a wide range of storage devices and file formats, helping users display content instantly.
Extensive input/output options
As a fully-featured high-end monitor, the PA238Q offers a complete port and connector array. HDMI makes it effortless to insert the PA238Q into any modern multimedia and content sharing setup, while the inclusion of DisplayPort, DVI-D, and D-sub maintains connectivity options with a wide range of devices so consumers can use the monitor as a single display for multiple sources.
  • MODEL PA238Q
  • DISPLAY PANEL 23” (58.4cm) 1920 x 1080
  • DISPLAY COLOURS 16.7 million ,72% NTSC (CIE 1931)
  • BRIGHTNESS 250 cd/m2
  • CONTRAST RATIO Native 1,000:1 / ASCR 50,000,000:1
  • VIEWING ANGLE (CR ≥ 10) Horizontal:178°/vertical:178°
  • RESPONSE TIME 6ms (GTG)
  • MAX POWER CONSUMPTION <58 W (w/USB HUB) typical <33W (EPA 5.0) / power saving < 1W / off= 0W(hard switch)
  • SPLENDID VIDEO INTELLIGENCE TECH 5 modes (standard, sRGB, scenery, theater, user)
  • ASPECT RATIO CONTROL 1:1, “FULL”, “4:3″ ,”Over Scan” (for HDMI)
  • VIDEO I/O DisplayPort 1.1a, HDMI 1.3, DVI, D-sub
  • AUDIO I/O 3.5mm mini-jack (for HDMI and DisplayPort)
  • HEIGHT ADJUSTMENT 0-100mm
  • PIVOT 90° (clockwise)
  • SWIVEL +60° to -60°
  • TILT +20° to -5°
  • VESA WALL MOUNT 100mm x 100mm
  • DIMENSIONS 548.8mm x495.7mm x201mm
  • NET WEIGHT 5.5Kg
  • CERTIFICATIONS Energy Star , UL/cUL, CB, CE, EuP, FCC (Class B), CCC, BSMI, Gost-R, C-Tick, VCCI, TCO5.2, TUV-GS, TUV-Ergo, ISO-9241-307, PSB, J-MOSS, Taiwan Green Mark (optional), HF (optional), RoHS, WEEE, Windows® 7 WHQL, Mac compliance
