איך kenwood ברסיברים
איך kenwood ברסיברים ואיך בכלל הדגם הזה צפציפי למערכת סטנדרט KRF-V5060D
וכמה RMS היא מוציאה לערוץ
רב תודות.
AUDIO section (KRF-V5060D/V5560D)
Rated power output during STEREO operation
100 watts per channel minimum RMS, both channels driven, at 8Ω from
40 Hz to 20 kHz with no more than 0.7% total harmonic distortion. (FTC)
Effective power output during SURROUND operation
FRONT (1 kHz, 0.7% T.H.D. at 8Ω one channel driven)
100 W + 100 W ...............................................................................
CENTER (1 kHz, 0.7% T.H.D. at 8Ω one channel driven)
100 W ..............................................................................................
SURROUND (1 kHz, 0.7% T.H.D. at 8Ω one channel driven)
SUBWOOFER (80 Hz, 0.7% T.H.D. at 8Ω one channel driven)
(KRF-V5560D) ...................................................................... 100 W
Total harmonic distortion ........................... 0.05% (1 kHz, 50 W, 8Ω)
Frequency response
CD ............................................... 20 Hz ~ 70 kHz, +0 dB, –3.0 dB
Signal to noise ratio (IHF’66)
CD, TUNER, AUX, TAPE ...................................................... 95 dB
Input sensitivity / impedance
CD ......................................................................... 550 mV / 47 kΩ
DVD/6CH INPUT (KRF-V5060D) ........................ 550 mV / 10 kΩ
Output level / impedance
TAPE REC ............................................................... 550 mV / 1 kΩ
PRE OUT (SUBWOOFER) (KRF-V5060D) ............. 1.5 V / 2.2 kΩ
Tone control
BASS................................................................ ±10 dB (at 100 Hz)
TREBLE ............................................................ ±10 dB (at 10 kHz)
Loudness control
VOLUME at -30dB level ................................... +8 dB (at 100 Hz)
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KRF-V5560~5060~4060D%20(EN).pdf
הדגם הזה הוא לא משהו "לרוץ לספר לחברה" עליו, רסיבר פשוט וזול, אם תשים לב אפילו חיבורי הרמקולים שלו הם מן הסוג הפשוט.
קנווד היו בעבר (שנות ה-70) יצרנית מעולה של רסיברים ומגברים - אחת הטובות שביצרנים עם דגמים אגדיים, היום... כבר לא.
היה לי עד לפני שנתיים רסיבר של קנווד - דגם יותר ישן אך יותר בכיר ממה ששאלת עליו, הוא נחמד ולא יותר מזה, בטח בהשוואה לימאהה הנוכחי שלי.
מה התקציב שלך לרסיבר? אפשר למצוא משהו יותר טוב.
