פיענוח הודעה של 3DMARK
שלום.
הנה הלינק:
http://3dmark.com/3dm11/1143048
מדוע קיבלתי את הודעהת השגיאה:
Your result has the following problem(s) and will not be shown for example on leaderboards::Graphics driver is not approved
הדרייבר לא נבחן ואושר על ידם..ולכן הוא מבחינתם לא נתמך..
Q: I submitted a result to the ORB, but it says that my graphics driver is not approved by Futuremark. How can I get an approved driver? A: Please use one of the currently approved driver versions appropriate for your hardware configuration. You can find the list of approved drivers here: 3DMark Vantage Approved Drivers.
:xyxthumbs:
