הודעת שגיאה בראוטר CISCO
תרשום
router# show interfaces
ותדביק את התוצאה כאן..
אגב, למה שלא תעשה כל ממשק ידנית ותוותר על זה?
תעבור על כולם ותעשה
switchport mode acc
switchport acc vlan 1
  • תגובות 43
  • צפיות 4.3k
FastEthernet0 is administratively down, line protocol is down
Hardware is Fast Ethernet, address is 0014.f2e3.33ac (bia 0014.f2e3.33ac)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Auto-duplex, Auto-speed
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 input packets with dribble condition detected
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out
FastEthernet1 is administratively down, line protocol is down
Hardware is Fast Ethernet, address is 0014.f2e3.33ad (bia 0014.f2e3.33ad)
FastEthernet2 is administratively down, line protocol is down
Hardware is Fast Ethernet, address is 0014.f2e3.33ae (bia 0014.f2e3.33ae)
FastEthernet3 is administratively down, line protocol is down
Hardware is Fast Ethernet, address is 0014.f2e3.33af (bia 0014.f2e3.33af)
FastEthernet4 is administratively down, line protocol is down
Hardware is PQUICC_FEC, address is 0014.f2e3.33b6 (bia 0014.f2e3.33b6)
Internet address will be negotiated using DHCP
Auto-duplex, Auto Speed, 100BaseTX/FX
0 watchdog
0 output errors, 0 collisions, 1 interface resets
Vlan1 is up, line protocol is down
Hardware is EtherSVI, address is 0014.f2e3.33ac (bia 0014.f2e3.33ac)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec,
0 output errors, 1 interface resets
0 output buffer failures, 0 output buffers swapped out[br]פורסם בתאריך: 27.05.2010 בשעה 21:50:15
תרשום
תעבור על כולם ותעשה
switchport mode acc
Router(config-if)#switchport mode acc
Router(config-if)#switchport acc vlan 1
Router(config-if)#ip address 10.10.10.1 255.255.255.0
% IP addresses may not be configured on L2 links.
לאיזה ממששק אתה מנסה לתת כתובת IP?
תעשה show running config
ותדביק את זה כאן
router # show running config
FA 0
זה ממשק wan?????????
כי אם כן, אתה לא יכול לתת לו כתובת.
Current configuration : 810 bytes
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0
no ip address
shutdown
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
ip address dhcp
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
scheduler max-task-time 5000
end[br]פורסם בתאריך: 27.05.2010 בשעה 22:06:22
זה לא ממשק WAN אצלי הWAN זה FA4
אוקיי,
נסה משהו אחר, אני רוצה לראות אם יש איזשהו שינוי.
נסה טווח כתובות אחר אולי,
יודע ליצור פול של dhcp ולחלק אותו באופן דינמי לכל יציאה?
אוקיי,
לא יודע מה הפקודה?
אם בא לך לעזור אפשר לעבור למסינגר אם אתה מעוניין?
זה לא יעזור במחשבה שנייה,
יש לך show my pc שאוכל להשתלט ולנסות לעזור להגדיר?
שלח לי את הסיסמא לדוא"ל
Morpci@gmail.com
שולח לך בפרטי
אוי, כמה בלובלי מוח....
את הפקודה sh ip int brief אתה מכיר? :smile1:
אני הולך לישון. אם יש עדיין בעיות אשמח לנסות לעזור מחר.
yourname#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 unassigned YES unset administratively down down
Vlan1 10.10.10.1 YES NVRAM up down
מה עכשיו? :jump:
קודם כל אני מציע לך ליישר את התוכן באנגלית לשמאל או לטאג של קוד כדי שאפשר יהיה לקרוא אותו בצורה נורמאלית.
בוא נחזור רגע להתחלה.
מה בדיוק אתה מעוניין להשיג ולמה אתה רוצה לקבוע כתובת IP לממשק הספציפי הזה?
אני מזכיר שוב שמדובר בISR ולכן הרבה מושגים ודרכי פעולה שאולי היו מוכרים לך עד עכשיו לא תופסים.
לפני שאתה עונה תקרא גם את מה שיש פה כדי להבין פחות או יותר מה הכיוון.
מה שאני רוצה סה"כ זה להפעיל ולעבוד עם הראוטר
לקנפג את הWAN שאצלי זה ממשק FA4 לקבל כתובת מISP באופן דינמי
ולהגדיר DHCP לחלק כתובות וממשקי הLAN
זה בשלב ראשון אח"כ אני מעוניין לנסות ולעבוד עם הSDM
וגם להגדיר VPN ופתיחת פורטים
ה SH IP BRIEF לא נתן לך הסבר על הנושא?
התשובות ממש כתובות שם...
