איני מוצא דרייבר כרטיס רשת שאינו מובנה בלוח
דרייברים מצאתי למעט כרטיס רשת
אשמח לעזרה.
--------[ EVEREST Corporate Edition ]-----------------------------------------------------------------------------------
Version EVEREST v5.30.1900/he
Benchmark Module 2.4.273.0
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer PASCAL
Generator Ayal
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP RTM)
Date 2010-04-07
Time 21:11
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Intel Pentium 4, 3000 MHz
CPU Alias Prescott-2M
CPU Stepping N0
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3
Original Clock 3000 MHz
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 2 MB (On-Die, ECC, ATC, Full-Speed)
Multi CPU:
Motherboard ID Grantsdale-G
CPU #1 Intel® Pentium® 4 CPU 3.00GHz, 3000 MHz
CPU #2 Intel® Pentium® 4 CPU 3.00GHz, 3000 MHz
CPU Physical Info:
Package Type 775 Contact LGA
Package Size 3.75 cm x 3.75 cm
Transistors 169 million
Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Die Size 135 mm2
Core Voltage 1.3 V
I/O Voltage 1.3 V
Typical Power 84 W @ 3.00 GHz
Maximum Power 101 W @ 3.00 GHz
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
CPU Utilization:
CPU #1 / HTT Unit #1 0 %
CPU #1 / HTT Unit #2 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel® Pentium® 4 CPU 3.00GHz
CPUID Revision 00000F43h
IA Brand ID 00h (Unknown)
Platform ID FFh (Unknown)
HTT / CMP Units 2 / 1
Instruction Set:
64-bit x86 Extension (AMD64, Intel64) Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD 3DNowPrefetch Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
AMD MisAligned SSE Not Supported
AMD SSE4A Not Supported
AMD SSE5 Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Supported
IA Supplemental SSE 3 Not Supported
IA SSE 4.1 Not Supported
IA SSE 4.2 Not Supported
IA AVX Not Supported
IA FMA Not Supported
IA AES Extensions Not Supported
VIA Alternate Instruction Set Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Supported
Conditional Move Instruction Supported
LZCNT Instruction Not Supported
MONITOR / MWAIT Instruction Supported
MOVBE Instruction Not Supported
PCLMULQDQ Instruction Not Supported
POPCNT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Advanced Cryptography Engine 2 (ACE2) Not Supported
Data Execution Prevention (DEP, NX, EDB) Supported
Hardware Random Number Generator (RNG) Not Supported
PadLock Hash Engine (PHE) Not Supported
PadLock Montgomery Multiplier (PMM) Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Digital Thermometer Not Supported
Dynamic FSB Frequency Switching Not Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Supported
Frequency ID Control Not Supported
Hardware P-State Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
1 GB Page Size Not Supported
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Supported
Debug Trace Store Supported
Debugging Extension Supported
Direct Cache Access Not Supported
Dynamic Acceleration Technology (IDA) Not Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Supported, Enabled
Invariant Time Stamp Counter Supported
L1 Context ID Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Nested Paging Not Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Supported
Physical Address Extension (PAE) Supported
Safer Mode Extensions (SMX) Not Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter (TSC) Supported
Turbo Boost Not Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
x2APIC Not Supported
XSAVE / XRSTOR Extended States Not Supported
CPUID Registers (CPU #1):
CPUID 00000000 00000005-756E6547-6C65746E-49656E69
CPUID 00000001 00000F43-00020800-0000649D-BFEBFBFF
CPUID 00000002 605B5001-00000000-00000000-007D7040
CPUID 00000003 00000000-00000000-00000000-00000000
CPUID 00000004 00004121-01C0003F-0000001F-00000000
CPUID 00000004 00004143-01C0103F-000007FF-00000000
CPUID 00000005 00000040-00000040-00000000-00000000
CPUID 80000000 80000008-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000000-20100000
CPUID 80000002 20202020-20202020-20202020-6E492020
CPUID 80000003 286C6574-50202952-69746E65-52286D75
CPUID 80000004 20342029-20555043-30302E33-007A4847
CPUID 80000005 00000000-00000000-00000000-00000000
CPUID 80000006 00000000-00000000-08006040-00000000
CPUID 80000007 00000000-00000000-00000000-00000000
CPUID 80000008 00003024-00000000-00000000-00000000
CPUID Registers (CPU #2 Virtual):
CPUID 00000001 00000F43-01020800-0000649D-BFEBFBFF
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 63-0100-000001-00101111-060904-iSPGDL_G$CY915001_BIOS DATE: 06/09/04 18:06:30 VER: 08.00.10
Motherboard Name Intel Cherry Creek D915PCY
Motherboard Physical Info:
CPU Sockets/Slots 1 LGA775
Expansion Slots 4 PCI, 2 PCI-E x1, 1 PCI-E x16
RAM Slots 4 DDR2 DIMM
Integrated Devices Audio, LAN
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset i915P
Motherboard Manufacturer:
Product Information http://www.intel.com/products/motherboard/index.htm
BIOS Download http://downloadcenter.intel.com/default.aspx
Driver Update http://driveragent.com?ref=59
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 509 MB
Used 149 MB
Free 359 MB
Utilization 29 %
Swap Space:
Total 1246 MB
Used 86 MB
Free 1159 MB
Utilization 7 %
Virtual Memory:
Total 1755 MB
Used 236 MB
Free 1519 MB
Utilization 13 %
Paging File:
Paging File C:\pagefile.sys
Initial / Maximum Size 768 MB / 1536 MB
Current Size 768 MB
Current / Peak Usage 8 MB / 8 MB
Utilization 1 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Grantsdale i915P ]
North Bridge Properties:
North Bridge Intel Grantsdale i915P
Revision / Stepping 00 / A0
Chipset Manufacturer:
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets
[ South Bridge: Intel 82801FB ICH6 ]
South Bridge Properties:
South Bridge Intel 82801FB ICH6
Revision / Stepping D3 / B1
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type AMI
BIOS Version CY91510A.86A.0012.2004.0609.1806
System BIOS Date 06/09/04
Video BIOS Date 05/03/04
BIOS Manufacturer:
Company Name American Megatrends Inc.
Product Information http://www.ami.com/amibios
--------[ ACPI ]--------------------------------------------------------------------------------------------------------
[ RSD PTR: Root System Description Pointer ]
ACPI Table Properties:
ACPI Signature RSD PTR
Table Description Root System Description Pointer
Memory Address 000F4E50h
Table Length 36 bytes
OEM ID ACPIAM
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B01 D00 F00: Tul Radeon X300 SE Video Adapter
Offset 000: 02 10 60 5B 00 00 00 00 00 00 00 03 00 00 00 00
Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 8C 14 89 20
Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F02: Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [b-1]
Offset 000: 86 80 51 26 00 00 00 00 03 00 01 01 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 59 43
B00 D1F F01: Intel 82801FB ICH6 - ATA-100 IDE Controller [b-1]
Offset 000: 86 80 6F 26 00 00 00 00 03 00 01 01 00 00 00 00
B06 D03 F00: Davicom DM9009 Ethernet Controller
Offset 000: 82 12 09 90 00 00 00 00 31 00 00 02 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 FE 14 08 00
B00 D1E F00: Intel 82801FB I/O Controller Hub 6 (ICH6) [b-1]
Offset 000: 86 80 4E 24 00 00 00 00 D3 00 04 06 00 00 00 00
Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F00: Intel 82801FB ICH6 - LPC Bridge [b-1]
Offset 000: 86 80 40 26 00 00 00 00 03 00 01 06 00 00 00 00
B00 D1C F00: Intel 82801FB ICH6 - PCI Express Port 1 [b-1]
Offset 000: 86 80 60 26 00 00 00 00 03 00 04 06 00 00 00 00
B00 D1C F01: Intel 82801FB ICH6 - PCI Express Port 2 [b-1]
Offset 000: 86 80 62 26 00 00 00 00 03 00 04 06 00 00 00 00
B00 D1C F02: Intel 82801FB ICH6 - PCI Express Port 3 [b-1]
Offset 000: 86 80 64 26 00 00 00 00 03 00 04 06 00 00 00 00
B00 D1C F03: Intel 82801FB ICH6 - PCI Express Port 4 [b-1]
Offset 000: 86 80 66 26 00 00 00 00 03 00 04 06 00 00 00 00
B00 D1F F03: Intel 82801FB ICH6 - SMBus Controller [b-1]
Offset 000: 86 80 6A 26 00 00 00 00 03 00 05 0C 00 00 00 00
B00 D01 F00: Intel 82915G/P/PL PCI Express Root Port
Offset 000: 86 80 81 25 00 00 00 00 00 00 04 06 00 00 00 00
למה לא להשתמש בתוכנה שמוצאת דרייברים וגם מתקינה, כמו - Driver Magician לדוגמה ויש עוד לא מעט, במקום לשבור את הראש ולמלות דפים שלמים?.
תודה רבה!
אילו ידעתי מה רלוונטי לדו"ח הייתי מוצא כבר לבד.
גם עכשיו אין לי מושג איך הגעתם לדרייבר הזה.
תודה גדולה נוספת!
