23"-24" not TN up to 1900 nis
Hi All,
I'm looking for a 23-24" lcd screen as a secondary display for my HTPC
it will be used to watch movies and to read emails occasionally
aspect ratio MUST be 16:9 1080p because I use clone settings with the other display.
wall mount compatible with vesa100/75 is also a must
first option i can think of is Samsung F2380 - http://www.zap.co.il/model.aspx?modelid=736019
but it lack the vesa wall mount holes that I'm so eager to have
anything else I should consider?
לצערי אני לא מכיר מסך שהוא נמצא בקטגורית ה"הכול כלול" בתמחור שלך.
זהו המסך שכולל הכול מעבר לVESA.
I'm considering the 23.6" chimei (24ED)
it does have vesa 100 and it's offering decent value for money (900 nis) in the TN department
thanks,
Joel.
מסך מעולה!
