SAMSUNG SyncMaster SM2343NW
היי
ראיתי היום את המסך החדש הצבעים שלו לא רעים כלל והNATIVE RESO שלו היא 2048x1152
המסך מסתובב על צירו (בסיס מסתובב)
עד כמה זה פרקטי רזולוציה כזאת במסך כה קטן?
* Screen size: 23" Wide
* Brightness(Typical): 300 cd/㎡
* Contrast Ratio(Typical): DC 20000:1(1000:1) (Typ.)
* Resolution: 2048x1152
* Response Time(Typical): 5ms
* Viewing Angle(Horizontal/Vertical): 170˚/160˚ (CR>10)
* Color Supported: 16.7M
Signal Input
* Video Signal: Analog RGB
* Sync. Signal: Separate H/V, Composite, SOG
* Connector: 15pin D-SUB
Power
* Power consumption: 44 Watts.
Stand by Power(DPMS)
* Type: Built-in
Features
* Plug & Play: DDC 2B
* USB powered hub option: No
* Mac compatibility: Yes
* Multimedia Speakers: No
* Wall-Mount: VESA 100mm
* TCO: TCO03
* Cabinet Color: Black
* Special Features: Power off 0.3W(typ.),MagicBright3, Image Size, Color Effect, Customized key, MagicWizard & MagicKey & MagicTune with AssetManagement, Windows Vista Basic,MultiScreen S/W
Dimension
* Product Dimension(With Stand, WxHxD): 544.6mm x 408.8mm x 227.5mm
* Product Dimension(Without Stand, WxHxD): 544.6mm x 323.1mm x 72.9mm
* Shipment Dimension(WxHxD): 628mm x 146mm x 398mm
Weight
* Product Weight: 5.4Kg
* Shipment Weight: 6.9Kg
Stand
* Type: Simple
* Function: Swivel, Tilt
