מפרט HTPC לסלון 2400 ש"ח שהוא יותר טוב מ Mac Mini
אז תפעיל שיקול דעת. הוא אחלה גוף קירור כשהוא מחובר, אבל בגלל שהוא שטוח מאוד ורחב מאוד להכניס אצבעות מתחתיו בשביל לחבר אותו זה כאב ראש לא קטן.
This is the first time that I've installed a CPU cooler: It took me about 30 seconds to remove the standard (very loud) Intel heatsink, and it would have taken me 30 seconds to reinstall it. But it did take me 1 hour and 30 minutes and some blood loss to install the big shuriken!!
If you look at the shape of it you notice that it is very flat and wide which means that the fixing pins are located UNDER the heatsink. There is a space of about 1.5-2cm to squeeze your fingers in AND press the pins down AND then twist them clockwise to lock them!! Remove PSU, ram, PCI EX cards etc and it is still tedious. Works very quietly though
big shurikan לא יהיה יותר יקר?
