זקוק למפרט גיימינג - 3800 ש"ח, ללא ציוד היקפי.
games usually rely more on the graphics card you've got installed, and although the CPU does play a part, it's usally not a major one.
also important to note that while most games know how to use 2 cores, few games are designed to properly use more. so when it comes to games usually the clock speeds carry more weight. so a 3 core cpu at 2.8Ghz will do the trick, especially if you decide to overclock.
computer cases are somewhat a matter of personal taste, and I think that should guide your choice as much as anything. both the antec and the coolermaster are good cases, so there is no right or wrong case. just pick whichever one you like better.
(I've a feeling some people will jump and say the CM has a large cooler that's hard to find or replace, others will say the antec's 140mm is also rare, and it'll go on and on... just pick one.)
Right now I got something like that going on:
מעבד AMD Phenom II X3 720 Black Edition Box
¤748
כמות:1
http://www.skypc.co.il/product.asp?pid=AMD1293
לוח אם Gigabyte GA-MA78GM-UD2H
¤469
כמות:1
http://www.skypc.co.il/product.asp?pid=950725
כונן קשיח Westren Digital WD5000AAKS 3.5" 500GB SATA2 16MB
¤310
כמות:1
http://www.skypc.co.il/product.asp?pid=WDC1115
זיכרון G.Skill DDR2 4096MB (2048MBx2) 800Mhz CL 5-5-5-15 PQ
¤304
כמות:1
http://www.skypc.co.il/product.asp?pid=F2-6400CL5D-4GBPQ
כרטיס גרפי TwinTech nVIDIA GeForce GTX 260 896MB (216) DDR3 PCIe
¤999
כמות:1
http://www.skypc.co.il/product.asp?pid=TT-GTX260-896D3E-XT
צורב LG GSA-GH22N X22 SATA DVD
¤128
כמות:1
http://www.skypc.co.il/product.asp?pid=GSA-GH22N
מארז ללא ספק Antec Three Hundred
¤315
כמות:1
http://www.skypc.co.il/product.asp?pid=THREE-HUNDRED
ספק כח Seasonic SS-550HT 550W
¤413
כמות:1
http://www.skypc.co.il/product.asp?pid=SS-550HT
הרכבת מערכת מחשב + בדיקה
¤79
כמות:1
http://www.skypc.co.il/product.asp?pid=29
שרות Sky Fix VIP
¤99
כמות:1
http://www.skypc.co.il/product.asp?pid=vip
סה"כ מחיר לכל המוצרים:3864¤
I took this to a private technician and he gave me a price of 4,125NIS, which is extremely high.
I can get the VIP service of SKYPC store, which means extended warranty of three years for whole of the computer + totally free shipment forth and back if you got a problem, for three years also - all that only for an extra of 100NIS, and even then the skypc offer is much worthwhile.
looks like you're good to go
:xyxthumbs:
Thank you for all you help man! So much!
happy to help, take care man
:hi:
